- Jun 4, 2002
- 37,118
Help me understand this. Are you saying that simply mounting the fuel pump close to the tank can somehow overcome the starvation that occurs from fuel sloshing away from the pick up tube in the tank when the level gets below about 1/4 tank? No
I have been trying to avoid having to install an accumulator and LP pump in mine for about 15 years now. Kinda annoying to only be able to use about 17 gal of the 23 gal tank all these years.
Some people don't let the tank run low enough to have a starvation problem, nor do they get into angles while low on fuel that can cause starvation issues. For those who drive on straight level roads, no accumulator is needed. And if you keep enough gas in the tank, also no need for an accumulator.
Accumulator is only needed when driving at angles and fuel levels that create a starvation issue with the fuel pickup in the tank. If you can avoid using a second pump and an accumulator, great. Newer cars and trucks have carefully shaped baffles to control slosh and keep the pump fed without the need for external accumulators. Some tanks have internal accumulators. The external accumulaors are typically found on early EFI when the old carbed fuel tanks were simply adapted to EFI usage. Carbs don't need the accumulator that EFI does as the fuel bowl can keep the engine running for a brief period of time while the pickup tube runs dry.
