kbronco
- Aug 10, 2006
- 314
I'm having problems with getting adequate voltage to my in-tank pump. Was running great but dropped the tank to test the sender and now I have issues. I'm using Ryan harness and have 12v at the fuse block but past that in the harness the voltage drops to about 6.6v. Swapped the relays around and no change. Also tested the pump with 12v and ground direct from the battery and pumps like it should. Would appreciate any suggestions on what to try.
