EFI- Pro Flo or Sniper etc.
-And how much is Ford SEFI system over these aftermarket kits that have gremlins?
-I just don't get it, Ford perfected EFI. Yes it is ugly but works, is reliable, and parts can be had at almost all parts places.
And at this point you are looking at used electronics that are in the neighborhood of 30 years old, 20 if going for the Explorer stuff.
The computers are needing rebuilding now. Plastic connectors are all super brittle now. Yes, there are some aftermarket harnesses out there.
Getting quality aftermarket replacment parts is hard. Yes, the quantity is there, but the quality isn't. So if you go all new, probably chasing at least one bad part. If failed completely, easy enough. But so often they work but are just way off spec.
Tuning isn't the easiest. Many of the problems that you read about in the stand alone EFI also exist in the SEFI, bad fuel systems for example.
duffymahoney
New ecu's are getting better and better. I have an haltech elite 750. Once setup, it basically tunes itself. But it's not for the faint of heart.
ngsd
I spoke with the owner of a tuner shop recently and he shared some frustration with the new Holley ecu's they are putting in the Snipers. (He is a Holley dealer) He mentioned that they have cut costs and there are a lot of interference issues with it built into the body and not being stand alone. The Facebook groups have a lot of the problems detailed out but just take it with a grain of salt since it is Facebook. You hardly ever hear about them working well but you will always hear when they won't. All that being said, I have installed 2 Snipers this year and the one thing that most people don't do is read instructions well. Mine are both working well and I am very happy with the performance. They are pretty simple but you also have to have some simple knowledge of how to tune and map these for peak efficiency or the aptitude to be able to learn or you will be better off having a tuner dial it in.
raleigh_bronco
I have installed a hand full of Sniper EFI systems now. I have had great results with it so far.
Install a cable, and progressive throttle linkage and a 1/4" phenolic spacer to help prevent heat soak. You have to reprogram for the progressive linkage, no worries because the Sniper has the option built into initial programming.
Looks more original, kinda hidden under Air cleaner. Runs Vey well with this set-up. Add the Hyperspark ignition for a true plug and play.
can you share some part numbers on the above recommendations for;
1. Progressive throttle linkage
2. 0.25“ spacer
thank you
gorf
I sent my fitech in for rma. They replaced it with a new ecu with external relay box. I’m assuming they are trying to address the heat soak issue. I’ve since moved on from fitech. If someone wants a deal on a fitech setup , let me know.
