EFI- Pro Flo or Sniper etc.
PDQ
For those with the Pro Flo, I'm assuming the intake height fit with the stock hood? I have a 1" body lift and would really want to make sure it fits before dropping that kind of $
Thanks for all the information here
nvrstuk
PNW
Check the height of the ProFlo intake manifold on line. I think it uses the SuperVic like I do and it is quite a bit higher than an Edelbrock Performer intake... like an inch or so?? Do the math- its easy.
Go on line, take the two measurements you need and make sure it will clear.
jmangi62
Had nothing but problems with Fitech. Finally found a guy who was able to tune it. Runs well now but I'd never do it again or recommend it to anyone. Same guy says Sniper much easier to tune if you know how.
Sent from my iPhone using Tapatalk Pro
Same here, nothing but problems. Placement of the inline pump appears to be a factor of the non running saga of my truck.:cry:
Remos69
SW Florida
Both issues with my FiTech were the fault of the builder, and the FiTech installer. The builder routed steel file lines too close to the headers on my 351w and would vapor lock. I had him install braded fuel line and shield the heck out of it. The second issue is when I went to internal timing control and went to an adjustable rotor. While driving at speed the engine cut off and would not restart. Found the adjustable rotor had slipped because the installer had forgot to loctite the screw after adjusting the rotor. After each issue I yelled and screamed at them. When my wife came out to see what was going on, I had to tell her each time about my screw-ups. ��
blubuckaroo
Grease Monkey
Ridgefield WA
My main concern with the throttle body units is that they have the brain internal and it's right on the of the engine Why would the manufacturers do that? Electronics hate heat.
Time will tell.
nvrstuk
PNW
... because they wanted a simple package and a unit that would last as long as the warranty would??? and then the could make more money selling parts??
If you think electronics on the throttle body is bad, many OEMs have been putting transmission computers (the actual computer, not just the solenoids) inside the transmission valve body. Been doing that for decades.
blubuckaroo
Grease Monkey
Ridgefield WA
Maybe so, but if you google this, some of these aftermarket throttle body injection systems have been having issues with heat on the controllers.
nvrstuk
PNW
Exactly- along with those heat issues
Fords seem to be having issues because the distributor is closer to the TBI "brain" and they are suffering from magnetic field and similar issues. Some have cured their tuning issues by removing an HEI style distributor (go back to separate coil) or putting a small lead shield between them as a temporary trial solution.
blubuckaroo
Grease Monkey
Ridgefield WA
Mine is a Victor Jr manifold.
hossbronco
The Pro Flo 4 uses the Victor Jr. for the 302 and the Super Victor for the 351. Not a bad platform for fuel injection.
PDQ
So Blubuck, in the interest of simplicity and benefiting from others who have already gone through this, did that setup work under the stock hood, and/or did you need find a solution for an air cleaner? We have similar setups looking at your write up and you talked me into the Hooker headers as well.
Subscribed to this thread so thanks to all.
SavageBurro
I run the proflo4 w 351w. Barely fits under stock hood with 1" body lift using drop air cleaner base and 2" thick element- but it does fit. Love the system and highly recommend it. Someone asked about issues at first startup. I did not have any - the whole process was simple and straightforward. The proflo4 is awesome. That said- If I had found a complete low mileage donor 5.0 explorer and lightning lower intake for reasonable price- I would probably have gone w obdII from explorer. You get better cooling, newer serpentine accessories, and parts are more likely to be available 20 years from now. The proflo4 was pretty darn easy. Most time consuming part is making sure wiring is good, fuel delivery system is good and no exhaust leaks. I have never dyno'd my engine but wow it sure woke up with the pro-flo4.
I have not used sniper or fitech, but know a few people that have had probs w fitech. Couple switched to sniper. One still runs FiTech. One of them wheels a lot and says the sniper throttle body still 'pools' fuel in one end of the intake if idling on inclines for a period of time... doesn't cut out but runs rough when that happens.
nvrstuk
PNW
ProFlo4
Engine vacuum is recommended to be above 8in. Edelbrock prefers 10 in hg or more.
Something to think about if you have a radical engine build going on.
Unlike the Stang '89-93 ecu with a Qtrhorse you cant go open loop at low rpm until the O2 sensors get better readings.
10in of vacuum or more probably qualifies 99.7% (guessing) of all Bronco engines on the road/trail. ;) So don't worry, just be aware
markw
Regarding heat soak with Fitech. Cured it with a 1” composite spacer. Just barely had room. But it worked.
sticknstring
I run the Pro-Flow 4 on my 331 stroker. As was mentioned about a 1 inch body lift is necessary and the time consuming part was the wiring and the fuel system mods were the time consuming part. It runs awesome, my only complaint is the somewhat limited tuning parameters. I would like more tuning ability in the cold start and high idle speed while cold. My initial startup was easy and it is much simpler to tune that my LS1/Holley system was but not nearly as many parameters to tune. I'm very happy over all with the Pro-Flo 4.
ChrisC74
What are you using for an air cleaner? I have a 331 w/ 1" body lift also and am hitting the distributor with my 14" round drop base w/ 3" filter element
sticknstring
It is a small, Summit Racing, small chrome filter that is about maybe 2" tall. There isn't much room as you well know. I don't recall the part number off hand. My Bronco is in storage right now but I could get you more info when I get it out.
bronco italiano
-And how much is Ford SEFI system over these aftermarket kits that have gremlins?
-I just don't get it, Ford perfected EFI. Yes it is ugly but works, is reliable, and parts can be had at almost all parts places.
