EFI Project weekend...New update
Broncoward
Broncoward
Rolesville
OK got it going....... running rough to tired to work any longer...had an injector leaking so had to tear it back apart rebuild the injector again...o-rings ripped?...new too...fixed now and will time it and let it run....tommorrow.
Pa PITT
Stephenville TEXAS
Intake
I just spent about 3 hours over on EBAY ...Looked to me like one of the Eddlebrook intakes would have much more room ..and more dollars also..
Broncoward
Broncoward
Rolesville
M/C Clearance fixed
OK so I placed a washer behind the M/C. Grinding was taking awhile and the amount of clearanced gain was very small. This is the fix picture
Broncoward
Broncoward
Rolesville
Almost there
OK last night I got to start but got late so couldn't fine tune
1. VSS Cluster Bleep
2. Just about wired up
3. fuel line mess...
last three different angles of it buttoned up
Still left
timing
BC throttle cable adjusting
And drive
Broncoward
Broncoward
Rolesville
Still idles rough...so working out bugs...runs great at anything above idle..got to search the forum here to see what others have done
brewchief
Did you cap all the vacuum ports? IIRC there is one between the upper and lower intakes for the power brake booster.
HoosierDaddy
Set base idle , set tps for proper reading , timing .... hmm what else ?
How rough , how long has it idled ? The computer does learn , it takes a bit.
Pa PITT
Stephenville TEXAS
relearn
I was going to ask if a ford computer has to go thru a relearn ..a while back at work we had one that took over 45 minutes of relearn time most of ours learn in about 5 stops..
jw0747
San Antonio, TX
Here's a great web site with info about getting the idle corrected. All Parts excellent but Part 3 especially good about steps required for computer "relearning."
Once when my battery was disconnected for a long period, it wouldn't idle worth a darn. Followed the instructions under Part 3 on the web site below without adjusting the throttle body and it got the computer corrected. My computer needed to "relearn" was only problem. Letting it sit for half hour worked and it ran like a champ...
www.muscularmustangs.com/iac.php
HoosierDaddy
Great link , I've seen that before ....it in my "favorites" now . Thanks
Broncoward
Broncoward
Rolesville
OK Running tested runs pretty good!!!!
OK Running tested runs pretty good!!!!...Lots of torque wow!!!!!
OK got the codes..the one that concerns me is ...91..Left O2 sensor.and 23 closed TPS sensor volts higher or lower than expected.......I have an exhaust leak and I have bent this o2 sensor in the process....ugh...I have Shorties coming..and the O2 sensor I'll get new....
Question 1...I have the cam/302 with the non-HO firing order and the computer is HO firing order...so the rough idle is expected...but its getting better...so will this set up cause the O2 sensor....code?
Question 2...TPS sensor volts higher or lower than expected...is this cause I raised the idle screw on throttle body?......to help Idle!....The KOEO test gave me that code and then I adjusted.....it then was not present...but with KOER test it was present again....Let me know what you think
Broncoward
Broncoward
Rolesville
Cool I'll be all over this site.. here in a second.......I messed with the throttle body screw...maybe I should have left it...lets see...thank you guys...This is why I became a contributer to this site...
More to follow
Broncoward
Broncoward
Rolesville
OK it good...I have plan for the codes...what else?
Should I have a whirring sound...is it the filter mass-air set up...whistling whirring?
HoosierDaddy
I have the same set up (non-HO) cam. I bumped my idle up a bit to smooth it out. It is not bad at all now. I did have it idling like a top fuel dragster for awhile :) , but it drove me insane at stop lights , always thought it was going to die , though it never did.
It should not cause the sensor code.
Q#2 : The tps probably needs adjusted , which you probably have done by now using the link posted earlier.
Broncoward
Broncoward
Rolesville
Q#2 : The tps probably needs adjusted , which you probably have done by now using the link posted earlier.[/QUOTE]
No sir I haven't got to it...ugh the wife had other plans...ok tommorrow...that's my first order of business when I get off.....I got it as a favorite....OK thanks....its running even better than before...I should have left the idle screw alone..that was my carb personality coming out....
How about the whirring sound coming from intake...if you lookat my setup do you believe this to be normal?
HoosierDaddy
Wish mine was here to start and listen to , don't recall any odd sounds. Seems like you got a decent amount of mechanical ability , does it seem wrong ? Hard to give an answer without actually hearing it.
Off topic , hows the NV3550 working for you , been eyeballing that for awhile now , for what is going to be my mall crawler bronco.
jw0747
San Antonio, TX
I would say you'll be okay once you get the TPS voltage set.
Mine is also an early firing order cam and surprisingly mine has never had a rough idle problem. I went into this project with real concerns about not changing the cam but after talking with our local f.i. specialists I elected to
keep the old cam. Now almost two years later I cannot tell any difference in the idle vs. when it had a carb.
On setting the throttle body adjustment, no big deal as long as you followed the Part 3 instructions and set the idle at about 700-800 rpms.
Don't know about the whirring sound. You might want to check to see if something's dangling loose around the internal parts of the mass air sensor.
