EFI Update/ Questions
WSM29
Well I went down to Wilmington Friday night and picked up a few parts. I got all the bigger parts cleaned up and painted. I am planning on getting a fuel injector reseal kit to put new o rings and caps on the injectors. I was cleaning up the stock rails when the one rail connector (?) pretty much just slid out. Upon further inspection, I saw that the housing is mashed. I tried pushing the lines back together and they will not stay locked in. Is there a work around for this or are these rails now junk? The stock rail pickup and return lines seem really long, and I don't think I have seen anyone use them on this conversion. What did you guys use in place?
Also, the TPS... I didnt grab anything out of the transmission, but when reading the BC broncos EFI page last night, it talked about the TPS going into the Dana 20. Did I miss this sensor when I pulled my parts?
There are a ton of vacuum ports/venting on the upper intake, throttle body, ect... I am definitely going to have to do some reading or get a chart when I get ready for that part of the install. How many of you are running an EGR delete? Pros/Cons?
Going to start looking at all my fuel system today. I have the Sherman Tank, would getting an in-tank pump be my best option since I already have the tank? Any recommendations on the model/brand?
Thanks again! I hope to have all the parts in by this next month and will start the conversion then. I am reading through all the articles from bronco driver pretty much everyday. With the parts in my hand now, it starts to make a little more sense!
TPS is Throttle Position Sensor. It is at the throttle body
VSS is Vehicle Speed Sensor. That is the one that goes into the speedometer gear in the transmission (transfer case in 4WD).
VSS isn't always needed. If you have a stalling issue after engine braking, adding the VSS back in is usually the fix. Don't sweat it right away, but keep it in mind for later.
WSM29
WSM29
I just caught that! I must of had a few too many last night when I was reading!
TN1776
When it comes to fuel systems I like to err on the side of caution. You do not want to have fuel leaking onto a hot engine or worse, exhaust. You might try massaging that fitting back to "round" by gently working on it with a piece of round stock, but again I'd test the heck out of it if I was at all successful in fixing it.
This may be a good excuse to go yank another rail from a junkyard or pick up one of the aftermarket variants. I believe my rails were among the cheapest junkyard parts I bought for my conversion.
TPS is up on the throttle body (throttle position sensor). You may be talking about the VSS (vehicle speed sensor). I do not run one at all (manual tranny). So far I can't even tell that anything's missing. I have spoken to others who complain of hanging revs and the engine dying when you push the clutch in but I've not had that happen at all yet.
The vacuum ports will mostly get plugged. It doesn't really matter which ones you use so plug the ones that result in your vacuum line routing looking the worst. If your run vacuum brakes, its really obvious that there is only one port that size for the brakes.
I run the sherman tank with an in tank pump. I switched to this after running a different tank with an external pump for a short time. External pumps can be a little finnicky in my experience. I did not want to run dual pumps or an accumulator and was having some problems with the external pump so it was an easy decision for me. So far so good... couple hundred miles on the in-tank pump (a mustang unit) and all good so far.
WSM29
WSM29
I am going through old fuel injection and just looking at parts and figuring out what they do so i have a better understanding. There are a few parts that I don't believe I have.
Idle Air Bypass (IAB)
Barometric Pressure sensor (BP)
I have the MAP sensor from the firewall. Does that replace the BP sensor?? Look very similar. Also, I have a few parts that the junk yard mech said I might need for the swap and he through them in as free bees... I cant remember what he called them and what i needed them for though... He spoke pretty fast! Pics are attached. I have not seem them in any of the photos from the articles or from old fuel injection. I am guessing I dont need them... Whatever they are.
WSM29
WSM29
Another question--
The Engine Coolant Temp sensor is mounted on a dual set of rails that connect to the lower intake. The rails come out the back of the intake. Is there any where else this sensor can be mounted and what do I hook up to the end of these two rails if it cant be mounted anywhere else??
WSM29
WSM29
I lied-- I do have a BP sensor. Since the mustang has the MA setup, the MAP sensor isnt on that setup. I had to look really close at the BP sensor and saw it has a different port on the left side. So I think I am back on track with what sensors I have. I still dont see a IAP. Will this be needed?
EDIT- Just ran the part number... e8ef-12a644-a2a Its saying MAP sensor. Now I'm confused, based off the photo on the articles, it shows I have a BP...
Sporto
Another question--
Those are your heater hose connections. There is a new bypass hose that is now needed to connect one of these to the water pump in the open front pipe, and then the two ports to the heater core connect to the back ends of these pipes. There are fitted hoses from another application that fits these back hoses pretty well, I just don't remember the part numbers off hand.
Hope this helps.
Rich
It is the same sensor. MAP is hooked to the manifold, BP is just open to the atmosphere.
WSM29
WSM29
Anyone have any pics of how the bypass hose is routed??
That 90° elbow hose that goes from the thermostat housing to the waterpump? They sell the hose too long, you have to trim the ends to fit.
WSM29
WSM29
I go the 90, it should be the same as with a carbed intake. Just referring to the hose that sporto is talking about. The dual rails..
Sporto
OK,
I hope these two photos are helpful. I am at work and these were on my phone, so this is about as close as I can get right now. If you need more pix, send me a PM or reply, I will get whatever you need.
Now the first picture shows the waterpump and the tube for the heater hose. This is connected with a 8" or so prefit hose that you can buy at any auto store. I got mine for an 86 Mustang since that is what this EFI came from. I did have to trim it to get it to fit right, but it is an easy task.
The other picture shows it in place, as you can see it is connected.
One thing to watch for on the back of these metal tubes. There is an incoming and outgoing tube for the heater, and the incoming (to the heater) has the ECT sensor in it right behind where it meets the intake. If you are running a heater control valve to restrict coolant from entering your heater core, then leave it cracked a little bit or open all the way. The computer needs an accurate reading of your engine coolant temp to properly tune the engine, and if there is not a steady flow of hot water on this sensor than you're likely to get a code thrown from the ECM. If you close it all the way off then this is restricting the flow of coolant and your reading and tune may be off. I know that there are some suggested solutions to work around this, but I was getting a code on mine stating that my ECT was out of range, and as soon as I opened that valve it went away.
Just something to consider.
Rich
Sporto
Here are the part numbers for the heater hoses that I used. These are Advance Auto part numbers and can probably be cross referenced.
(2)Dayco Drive-Rite 90 Degree Coolant Hose
#80404
(1)Drive-Rite Molded Heater Hose
Part No. 303671
The second one I had to trim the one bend off. I test fit it a dozen times before doing so, but it worked out okay.
Remember your application may be different than mine, but this is what I used.
Good luck...
Rich
WSM29
WSM29
So I had 24 hour duty last night, so I couldn't get much done in the way of reading. Today I got caught up on this post and I want to thank you all for the good input that is being feed to this EFI Noob! I do have some more questions or areas for input. With the bad fuel rail issue and me thinking about the heater hose lines... I remembered the guy that was pretty much trying to give away that 88 Lincoln 5.0 setup... So I rolled over there and he still had it. I got to looking and he does have the IAB sensor that I didn't have on my mustang TB. Score?? I plan on putting that sensor on the Mustang TB as the Mustang looks a bit bigger. The 88 also has another type of water neck for the intake. This neck still has a port for the ECT Sensor, but looks like I would be able to run my stock heater hose setup. Any input on this?? Also, Would there be any size difference between the mustang fuel rails and the ones on this lower? The fittings look in a lot better shape on the 88 lower. They do only have the 14lb injectors, but I still plan on using the mustang intake, just putting the 19lb injectors in the 88 fuel rails. Would there be an issue with this?? He gave me the MSD coil and Dizzy as well. So I ended up with some spare parts or parts to swap around to make everything work. He noticed I had a 12 pack of Coors Light in the cab when I pulled up and thats what it cost me for the complete lower, a spare upper and the coil and dizzy... Not too bad in my opinion!
Lastly, I have a brand new Champion radiator and shroud... I dont have the funds invest in an explorer serp setup right now, well I really just dont wanna burn the money I have in the new radiator! I know I need to run a 3G alternator now, but has anyone ran into any issues with running EFI along with the stock bronco belt and pulley setup? Thanks again for all the continued input!
Sporto
"I know I need to run a 3G alternator now, but has anyone ran into any issues with running EFI along with the stock bronco belt and pulley setup? Thanks again for all the continued input!"
Mine is all stock. Alternator, radiator, pulleys and belts...No serp or 3G. No problems thus far. I also use the stock hose neck and hose for the radiator. The one that is vertical is for the serp setup.
I can see the injector harness too in the pictures. Make sure to grab that if you did not already, also note where the ACT sensor is. It is usually in the lower itself near the 5th cylinder. BC Broncos EFI page has a great picture of this.
KyleQ
I would toss those fuel rails and get a set of rails off a F-150 - the connections are at the back (instead of the front).
I would hook up the ECT into the intake manifold where it should be and block off or just leave the unplugged sensor in that spot on those Explorer coolant tubes.
As for vacuum lines - I've only got the one from the valve cover and the other to the FPR, you don't need anything else.
You can run without the 3G, but it cleans up so much wiring, is a bolt in swap and provides much better power - its' $29 from my yard for a 3G anyway...
FYI - with the Explorer serp you can also run the Explorer radiator, fan and factory shroud - $100 lifetime warranty radiators sure are nice... in stock around here too!
