Holley Terminator EFI - Install (Update 6-7-18)
JWMcCrary
This will be a slow process but I haven't seen any other threads on it so I thought I would describe my install, problems and solutions, as I go along. Talked to some people at Summit Racing on Sunday when selecting a fuel delivery system and also to a highly reputable Hot Rod and 4x4 shop in Akron prior to purchasing the EFI. They speak highly of this system, a lot more so than the MSD system. Which is good because I hate MSD, but I will still be using my MSD distibutor, coil and ignition box. I am going to keep my stock fuel tanks. I thought about switching to a new larger tank but my stock tanks are in good shape and the way my rock sliders are allows my side tank with no issues. I am going to run strictly off the rear tank and use the Moroso filler neck adatper for the return line. I plan to plumb my 4070 electric pump that I have been using with the carb between the side tank and the vent hose on the rear tank using the T I got from BC broncos, transfer the fuel from the side tank to the rear tank when the rear gets low. Other than the T there was nothing to buy so why not. I am swapping my Duff long tubes out for BC's stainless shorties, which got sent to my PO box in MS, they are being rerouted now. I purchased the 2 into 1 magnaflow muffler shown in the pictures. First step is to get the new headers and muffler installed and have the wide band oxygen sensor bung in place before starting the EFI, hoping to have that done this weekend. Hopefully the new exhaust routing will have most of the exhaust on the passenger side and away from the fuel lines. It will be slow but will update as I make progress.
Cool JW. Can't wait to hear how it progresses.
You still running with the stock chassis harness, or has the electrical been upgraded?
I thought shorties were invented so they could fit into PO boxes. ;D
JWMcCrary
JWMcCrary
Exhaust is done and I like it much better than what I had. Long day at the muffler shop on a Sunday.
Brought the Bronco to work today, give it a better washing than the quick power wash it got right after OCBR, drive it around a little in case it never runs again after I start fooling with EFI. I'm a severe novice on EFI but will be tearing into it by the end of the week. This new system from Holley is supposed to be idiot proof, we will see, lol.
JWMcCrary
JWMcCrary
WOW, somebody is actually interested.
I will update Sunday night or Monday. Been working on a metal plate to attach to the rear inside of the frame that will have the pump and filters where I can take it in and out as an assembly. Removed the fresh air intake on the drivers side, I'm hoping to mount the ECU on the inside behind the dash in that spot if it will fit and I can get to it well enough to mount it. I hope it's running by Sunday night, stay tuned.
El_Ducko
LA LA Land
I am VERY insterested.
What made you choose Holley over FAST?
It seems the Holly kit is approx $2100.
I have found FAST master kits for around $1800.
I would be interested to know at the end how much you invested to get it cruising down the road.
Timmy390
Conway, AR
Same here.....
Added question.....The Holley kit doesn't come with a regulator. What are you planning on using?
Tim
JWMcCrary
JWMcCrary
Same here.....
Tim
That box at the left front that says Holley on it is the regulator. It will install in the return line after fuel leaves the Throttle body. I'm making a bracket to mount it at the back of the intake to have close and save some high pressure line going back to the tank. I will add the part# later. I will have about $2800 provided I don't have to buy anything else. You can save $300 of that by going with a cheaper fuel delivery system. I had some credits so I got the top one.
WheelHorse
Looks like I lit the fire of interest.
I'm big into R&D so I like to read or hear and discuss with feedback, different set ups.
Timmy390
Conway, AR
I'm guessing you bought Holly PART #: 526-4 Fuel kit Or did you just buy the regulator? Either way, to my untrained eye, $300 seems high for a pump, regulator, hose and couple of filters.....again I untrained eye.....
Tim
JWMcCrary
JWMcCrary
Tim
526-2
There is pic of it in the first post
BALCH-Autoworx
Good stuff, very interested! I've been eager to see some real reviews on this system before pulling the trigger myself. I could search your old posts, but what is your engine combo?
bax
Old Member
interested and hoping for a great install.
