Steve83
It's been a week - did you ever whack the relay?
He replace it with a new relay in post 8, then he replaced the ignition switch and key cylinder in post 15, and still has the problem.It's been a week - did you ever whack the relay?
Where do the three big cables attached to the starter relay go?
More specifically, where do the two large ones on the same stud go?
If everything else is connected properly, disconnecting your Red w/blue wire means that the starter relay/solenoid/thingy has failed and is giving full power to the starter. But that's only IF it's all connected properly. And yours has definitely been molested at some point in it's life.
no a serious spark is not normal, just a little one if you have a stereo or something. a larger spark means you have a large draw going somewhere. be time to do some testsI'll check when I get home from work. But if I remember. The two large on the positive side(battery positive & to starter/ or alternator(I didn't follow the wire down)) , negative side was grounded to the engine block.
Anyone else have any ideas?
Also When I go to connect the battery ground wire to test. There is some serious sparks too, like full current flowing through. I assume that's normal, just wanted to share.
Any update?
1)... in post 15, did you replace the whole ignition/starter switch or just the key and tumbler?
2)... in post 8 you replaced the starter solenoid. There is a small chance you received a bad new solenoid. Check by removing all wires from the solenoid and see if power goes from one side to the other. Continuity test. With nothing connected it should not.
The power to your starter comes through that solenoid. Did you check the connections before and after you made changes?
Yes I changed out the complete ignition switch and changed out the key tumbler. When I pulled my old tumbler out it basically fell apart. So I had to swap that and I picked up the Ignition switch from Oriellys.
I'll check to see if the solenoid is working when I get home tnight, and report back.
Question- so right now the starter is still hooked up and every time I go to put the ground on I get big sparks. I can swear a bit of slag has built up from the dozen times I have tried hooking up my ground.
So to continue testing I'm going to remove the starter cable off the solenoid. BUT won't full voltage/amps be running through the whole system? Is there anything I need to worry about when I hook up that ground? Like the issue somewhere getting red hot and burning up?
I'll unhook ground when done testing.
Right. Which means there is no starter solenoid on that truck - only the starter relay.That is a stock Bronco starter, Not a PMGR
You know it's not, because the starter is engaging every time you connect the battery. But it can be only one of two things. Either the solenoid itself (it's really a relay, not a solenoid) is bad, or the Red w/blue wire is getting power when it shouldn't.
I think you said you disconnected that wire and it still had the problem, so that leads back to something I'm pretty sure we already said. You could have a bad relay.
This even more common than charlie was saying. I'd say out of every story here of people replacing their starter relays with new store bought ones, about 60% of them experienced problems with them. Some right out of the box, others within a week.
So it's not without precedent.
