broncodriver99
So my '69 is not charging properly. I found the 3 pin connector on the alternator harness corroded and the center pin broken off. Installed a new harness tonight. The alternator is putting out 11.9 volts when connected to the battery and 12.2 on the positive lead when disconnected from the battery. I am going to pick up a voltage regulator in the am and try that. The question is does anyone know what is connected to the bullet connector on the voltage regulator harness? Looks like a capacitor of some sort. It is wire #152A in the attached diagram. Just wondering if it is something I should replace with the voltage regulator.
