dirtbikedad
Seemed to have no electrical output at all to headlights or ignition switch now.
Jumped across starter solenoid and it turns over. Replaced voltage regulator and starter solenoid as connections looked pretty corroded.
Checked all the fuses in the fuse box and they are good. Could it be the headlight switch???
How do I remove the headlight switch from the dash to check it?
