electronic egnition conversion or one piece??
six-six
Littleton, Co
Got to buy a new distributer for a 351w going in my 66, wondering which is best to buy? A regular distributer and then put the conversion for electronic egnition in it or mallory has a distributor that already is electronic egnition all put together. Whats experiences have you had?? Primarly a street bronco..
bronko69er
EB Addict
Renton, WA
Are you just trying to get rid of the points?
If so you can get a duraspark dizzy and an ignition module for around $100 at your local parts store.
70_Steve
Old Guy
X2 for Duraspark. Relatively cheap (used or remaned) and easy to install. Parts readily available at any auto parts store.
SteveL
Huge chevy guy
Hawthorne ca
hei conversion works great. It cleans up the wiring. Only 1 wire to hook up ign. under hood. 2 wires if you run a tach. You can get a cheap one(pro comp) for about $100 or pay more for a good one like MSD or DUI. I had bad luck converting the stock dizzy with the pertronics. It would heat up and crossfire in traffic.
six-six
six-six
Littleton, Co
Thanks i think im gona go with the all in one set up i found some that have the coil built in. Any thoughts??
SteveL
Huge chevy guy
Hawthorne ca
The built in coil is the HEI set-up. The coil is in the dist cap. Most the conversions have a 50,000 volt coil too.
SteveL
Huge chevy guy
Hawthorne ca
I'm not sure about the other conversions but with the DUI you want to run a decent aftermarket oil pump shaft. The stock ones have incinsistant lengths and don't allow it to sit all the way down in the block. This happened on my 72 and had to buy an arp shaft. I've had the DUI on both trucks over 8 years with no problems.
DonsBolt
Chestnut Hill, Mass
There are a few ways you can do it, all depends how much you want to spend
Like the other guys said there is the duraspark dizzy and an ignition module, the DUI, Pertronix and MSD both make ready to run Distributors, and maybee a few others.
You can also get a MSD Pro Billitt Distributor, with the MSD box or a Crane Cams Dizzy with the Crane Box.
I run a MSD Dizzy and a MSD 6AL ignition box
dji
I just did mine this afternoon. Rebuilt dist from 84 mustang GT and HEI module. Just regapped the plugs and it fired up like it never has before. Test drive in the morning;D
1sicbronconut
Painless makes a nice loom for the Dura Spark conversion, it's $100 but it's nice having all new wiring/plugs. I tend to like using the Dura Spark because when you break down in the middle of nowhere you can still find the parts.
