Emergency Brake Cable Failure
Jc.av8r
Would this explain why my e-brake is totally ineffective?
It appears the inside cable itself is intact but the white threading and metal spring exterior is frayed out. How does this happen and how difficult will it be for me to replace the cable? I need my e-brake!
NicksTrix
common deal. replace it and move on..
check rears. if too short just do them all at the same time
Fairly common. For the inner cable to pull, the outer has to withstand compressive forces. But it also has to remain flexible. If you think of the inner stretching, the outer is crushing. It just collapsed on itself.
The only tricky part about changing the cable is releasing the snap in fingers. Grab a handful of box end wrenches (grab the metrics as well). Slide them down the free end of the cable and find one just small enough that when it is pushed on it squeezes all the fingers at once. A little tap of the hammer is usually used. That gets the old one off. The new one is even easier to put in. Just push it in the hole.
J
Jc.av8r
Thanks.
Anyone aware of a tutorial video or walkthrough I can read? Never done this before.
