Engine building experts: intake gaskets
Digger556
I have a 351W with aluminum heads and intake.
I understand the need to properly size the port holes and the thickness of the gaskets, but what about material for various head/intake combos?
Does aluminum's differing heat expansion rate play into gasket design/material when all the OE parts were steel/iron?
Thanks!
blubuckaroo
Grease Monkey
Ridgefield WA
The difference in the gaskets is more related to the difference in the bolt torque. The standard gaskets that are used for iron intakes can't be properly compressed by the 18 ft. lbs. torque for an aluminum intake. Iron manifolds and their standard gaskets need 25 ft. lbs. of torque.
Yes, there is also the difference in expansion between iron and aluminum manifolds that can cause issues. That expansion can actually tear the gasket. This is why the long time recommendation on aluminum intakes, for the FelPro 1250 gasket has been changed to the 1250s3 with its steel reinforcement.
Digger556
Digger556
Thanks, that's a good bit of info.
jperry1290
Felpros on mine. I also used “gaskasinch” which I believe is made by edelbrock, kinda like rubber cent used to hold the gasket in place while installing the manifold
SteveL
Huge chevy guy
Hawthorne ca
Another vote for the fel pros. I've had good luck with just permanent but gaskasinch (yes by edelbrock) is a lot stickier. Just incase you don't already know throw out the end pieces and use a bead of silicone/permatex.
needabronco
Prescott/Farmington
The gasket needs to match the head, not the intake. So, if you have 69' 302 heads and a 96' GT40 intake, you'd use a gasket for a 69' head....
