Engine building tips?
highrlr
Bismarck, ND
I am going to be pulling and rebuilding my engine, tranny and t-case soon and I was wondering what the best way to build my 302 would be. I have decided I want to keep the 302, not sure about the tranny, has a c4 right now but would like to do an aod. Anyway should I rebuild the 302 that I have now or should I use a newer 302 that would be better? and what kinda things should I do to get some good power outa it? Any help would be appreciated, this is my first engine rebuild and im not sure how to build it. Thanks
For a first engine,
Get a book"how to rebuild a small block ford"
Go through it and rebuild the engine. Don't get carried away, keep it relitavly simple. To up performance, use a set of flat top pistons, 4 barrel carb. Don't do anything more then a mild RV grind cam.
After you get good at building engines, try another and get parts from different sources. Mix up some heads from this and parts from that. But just get a good basic engine rebuild done before you try anything fancy.
As for tips, get the book, don't skimp, get it balanced, Change all the little stuff while you are at it. Get a new thermostat, fuel pump, water pump, oil pump, HD oil pump driveshaft, etc...
Jeepster
Do a newer roller block. 5.0 ,Less friction = more mpg/HP. You still can slap on your intake/carb/pan......
Bronco Ben
Jckofalltrdes master/none
Coffeeville, Alabama
definetly do a HD oil pump driveshaft! at least do engine bearings, rings, gaskets,oil pump,waterpump,thermostat,....be sure to check your engine mounts and tranny mounts as well. I personally prefer the 87-93 roller cam HO engines from Mustangs, but .....any 302 with a fresh rebuild and mild cam is gonna make simular power with the correct exhaust, intake/carb combo. Its all about matching it all up.:)
Bronco Ben
wildbill
Old Bronco Guy
;D ;D ;D If you are going to build your old one DON'T get the kit parts get brand names and if you now what you want the motor to do get hold of a cam co. and find a good cam. ( Erson ) they make some nice off road cams also new oil pump not rebuilt. And on the crank if it wont clean at a 10/10 pay the core and go 10/10 will make a better motor. And on the rod/main & cam bearings go with CL-77's they work very good and double roller timming setup good luck.;D ;D ;D Bill :cool: %) :p
H
highrlr
Bismarck, ND
Thanks for the replys everyone, they help alot but I still have some questions. First off I was thinking of going with a roller cam and valvetrain, if I find an 87-93 roller cam 5.0 I would then have that but wouldnt there be alot of sensors and what not in the block to work with the computer? now since I will be going with a carb(either a jet built quadrajet or truck avenger) I know I dont need these, so what do you do with them if infact they are there? Another question is will any aftermarket carb intake bolt onto a newer 5.0? Oh and a dual plane intake is best for tourque right? I think I can put a roller cam in my block right? Does it need special machine work to do this?
WildBill- You said if the crank does not clean to a 10/10 to get a new one, what do you mean by "clean to a 10/10? you also said to use CL-77 bearings, those are Clevite's right? And what did you mean by a double roller timming setup?
Thanks again everyone, this site rocks!
Oh and one last thing, there was mention of heads somewhere, so I was wondering what I should do to the heads? Just a rebuild, ported and polished? New or different ones? I would like some aluminum heads for the weight savings but they are out of my budget and I have a budy that does some head work as a hoby so I was thinking of letting him do his thing with them, any suggestions on what to tell him to do?
thanks again, and sorry about the long post and all the questions.
trailpsycho
If your not going to use the EFI, find an 87 or 88 5.0 HO motor; they are cheap compared to the 89-93s since they dont have mass air. You can have the heads ported, polished and larger valves put in, but just a 3-angle valve job, porting and polishing with new lifters, springs, etc will be far better than your stock heads. The shortblock should be remachined, and you can decide on pistons, etc (listen to Wildbill)....or if its a low mileage 87 or 88, you could leave it alone and run it with your intake and carb, until you can afford to get fancy and build it right. If you leave off the EFI system (longblock), it is essentially the same as your 302, so a dual plane and carb and other normal accessories will get you on the road.
wildbill
Old Bronco Guy
;D ;D ;D If you look at some of the kit motors you will find like 20/30 crank in it and that is JUNK the 10/10 is as good as it gets. When you rebuild a motor you need to turn the crank if it is showing wear makes it like new and the CL-77 are clevite bearings. The double roller has 2 sprockets top and bottom (double roller ) cost a little more but well worth it. They dont stretch as much as a stock one will. hope this helps good luck.:p :p :p Bill :cool: %) :p
