collinbrewer
I have... it never got below 36psi.
Thanks Viperwolf. Can you speak to the loss of fuel pressure after shutoff? I'm concerned that maybe my injectors are allowing fuel to bleed pressure ultimately flooding the engine.
As for spark, I have spark but it doesn't seem very powerful. Not sure what would cause the car to spark fine from work to home, and then have weak spark 10 minutes after shut off. Any ideas there?
Another thought, my car does want to run hot(~220º) and I got to wondering if the ECT has any function in the computer?
I scanned back through this thread and didn't find a mention of what EEC your using. Pin 30 should be connected one of two places, depending on which EEC you have. Here's (part of) a diagram from oldfuelinjection.com that shows the differences. Either connect to signal common (Pin 46) or ground. I've verified this using the wiring diagrams in the Probst book.... so I am working on getting rid of that code 67, by jumpering pin 30 to pin 46 if for nothing else than to just be able to run my KOER, though I'm hopeful it will fix my no start issue.
the only peculiar thing I got was a code 13, which relates to idle control.
I can't see why this would be related to the ongoing no start issue but maybe some of you can?
