Engine Guru's....help with "sputtering"
Rmally
Knoxville, TN
I took the 71 out today for the longest ride since I've had it (less than 2 months) and while it didn't leave me stranded or walking it did give me a few increased heart rate episodes.
It fires right up and idles nice, ran perfect for about 10 miles then it had a few episodes of "sputtering" while in 3rd gear running about 40-45mph. It cleared and ran fine for awhile then did it again. Decided to cut the trip short and on my way home after stopping at a red light it coughed and sputtered in 2nd gear and when I got on the gas it sputtered even more.....I eased off the gas and it picked right up but every time I feed it more pedal it wanted to cough and sputter.
Any ideas on where to start with a diagnosis? I'm not a mechanic but have some basic skill just need a little direction. Where would you start the troubleshooting.
Thanks for the help.
Randy
PS....71 model with 302.
73azbronco
Every tuneup starts with the basics
Compression check including reading the plugs for condition.
Vacuum at idle, not just the number, but what's it look like.
Timing.
From there, you can start to determine if its fuel, ignition, or engine.
Rmally
Rmally
Knoxville, TN
Is it just under a load?
If you put it in gear and increase the rpm's does it still sputter?
Yes, when I rev it in the driveway it crackles and sputters. It was pretty smooth this morning but now its developed this issue. Thoughts?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Sounds like a fuel issue to me as well. I'd start with the simplest thing and check for a clogged fuel filter. Are you sure you have enough gas in the tank?
Rmally
Rmally
Knoxville, TN
Yes, just filled up the other day. I am running off the Aux tank as the main doesn't appear to be working ( I have another thread regarding that issue).
Since I have owned the Bronco it has only ran off the Aux tank. Thanks for the input, I will check the fuel filter (by the way does it just have the one in the engine bay or are others installed near tank?)
I should note that earlier today while it was running I did look in the engine bay and it has a clear filter. While the engine was running it looked like the filter wasn't filling all the way or either my eyes are playing tricks. Should it be full while running?
Spartan
Backwoods, KS
It's not vapor locking is it? Pull the gas cap and see if it still sputters.
That said, I'm inclined to agree with the others on a fuel issue.
Can you run a separate fuel supply to the carb?
Unhook the supply line to the carb and see if the fuel pump is pumping enough fuel from the tank, if not check your tank, lines etc-
like wise, if it still sputters (from a separate fuel source)then your clog is in the carb-doing this will tell you where your fuel clog is located.
With that clear filter, you might just have two at least.
The stock carb "usually" has one screwed right into the front of the float-bowl where the fuel line enters the carburetor. Some people leave it in when installing the clear filters, others replace it with a simple hose-barb screwed into the carb.
If the filter is still there, then you should replace it no matter what. Just so you know it's clean and not causing the trouble.
The fact that it didn't do it when you first started driving it while cool could mean that it was working fine with the choke partially closed, but when fully warm and the choke wide open, was not getting enough fuel (running lean) and causing your trouble.
But the filter is the first thing to check/replace.
And no, the clear filters don't always fill up. They're a good indicator of flow once you've learned how to read it's actions, but they are rarely without some sort of air pocket.
If you watch it while the engine is running, you will see very little movement most of the time (other than fluttering from the engine vibrations), then you will see short bursts of fuel flowing as the float level goes down in the carb and the valve opens.
Granted, this occurs fairly regularly and often, but for some reason you don't see it as a constant movement of fuel in the filter. More like an occasional surge.
The stronger that surge, the better your fuel pump seems to be. The weaker movements could indicate a weak pump, or a clogged filter upstream at the carb, or something else.
The pump can only push against things so much before it can't anymore. But revving the engine or watching it under load will usually show a stronger flow and more often.
Sorry for the long-winded dissertation. But it seemed like it would be good to become familiar with some of the idiosyncrasies of the beast. ;)
Oh, and speaking of filters, I got caught once by a couple of hidden filters inline that the PO had installed. Stock is just the "sock" filter at the end of the fuel pickup in the tank, and the screw-in steel filter at the carb.
Since your clear filter is an add-on, it'd be a good thing to follow the lines to the tanks to make sure there isn't a hidden little gem that will give you fits.
Rmally
Rmally
Knoxville, TN
Guys, I can't thank you enough, I will start my troubleshooting tomorrow. I really appreciate all the advice.
Hopefully I can get it sorted and get back to worry free driving. I also need to get a service manual, is the Haynes book I can get at the auto store a decent reference or should I get a factory manual.......or just pay a professional :eek:
Thanks again.
The Hayne's is adequate to start with. Gives you a few things you'll need, including decent wiring diagrams for the '73 and later EB's. Unfortunately though, the info tends to get a bit thinned out due to them trying to cover all Broncos and pickups through '79.
So some of the EB specific stuff gets lost in the shuffle.
I end up using the combination of an older Chilton's (before they got thinned out too) and the Hayne's. But for the goriest of details, there's nothing like the factory stuff. If you can find one, it's worth it for that hard to find info.
Unless you get it here that is!
Have fun.
73azbronco
Try running a bypass line from aux to feed line, bypassing the selector valve, those are notorious for allowing air into the fuel as it sucks up to the pump. Might also be why you can't get fuel from main. My symptom of a bad selector valve was fuel leaks around the valve
