Are you running an Engine Oil Cooler ? If you are what brand and what size are you running. Where do you have it located ?
Thanks,
Charles
Thanks,
Charles
Whats the point of a oil cooler? As long as the engine temp stays the same would the oil get hotter? And at what temp does oil no continue to lubercate?
OK, I raced BMW's using oil coolers, yes they help a race engine, ford 302/351? Not so much as noted above, unless you race them. Lots of extra plumbing and such to get no return on investment on a daily driver or even rock crawler. As has been said, RPM is what heats oil, not idling over rocks. Now, I do run an oil temp guage just to make sure your not getting over 275ish degree's.
My typical highway cruise rpm is over 3,000. And it has seen over 5,000 rpm on some snow runs.
ROI is low unless you race.
Best defence, oil temp guage.
$10 at pick & pull doesn't take long to return.
Deep snow is a good reason for an oil cooler. I have done bad things to engines in deep snow. It's extended high load, high rpm running, just like towing up a long hill.
I'm in AR so don't know what deep snow is.....how does it cause oil temp problems? I don't see the forest for the trees....Air is cold, snow is cold thus oil is hot? You talking about plowing snow? I've drove in 10 inches of snow and the air temps around 23ish and my rig stayed so cold the heater wouldn't work. Wife was cold and let me know it every 10 minutes or so....LOL
Not being a jerk, trying to learn.......
Tim
