Engine won't shut off! HELP!
jesus888
Atlanta, GA
So we finally got the SOB cranked, got the timing adjusted.
When we turn the key to the OFF position... it WON'T shut off...
EFI, 302, Petronix Coil, Centech Wiring Harness, 3G Alternator, Reworked Mustang Harness (Kolibar Customs).
Please give us any possible explanations...
Viperwolf1
electron whisperer
Relays are triggered by constant 12V instead of switched 12V?
jesus888
jesus888
Atlanta, GA
kolibar harness gave me a positive to connect direct to battery; so you are saying the main power source for the efi harness should be switched.
Viperwolf1
electron whisperer
No. But the relay triggers need to be connected to switched power.
jesus888
jesus888
Atlanta, GA
This was related to a defective alternator backfeeding the system. Alternator replaced, problem solved ;D
