G3 Alternator in 1975 5.0 Bronco - Engine Won't Shut Off
L
Lawson
Newbie
I'm searching around now. It appears to be a 12SI alternator. This link had some interesting things to consider about resistance and an alternate to ignition power source.
https://www.jalopyjournal.com/forum/threads/how-do-i-wire-a-gm-3-wire-alternator.30629/
Essentially I can possibly get my power from the ignition power at the coil. They also write of the light bulb creating necessary resistance in the system.
The part number of the alternator is: 7278F-6-135A-3 WIRE-12SI PLUG-SP
The fuel pump and EEC should be fed via relays as on drawing. Can't see your ignition/coil circuit on the drawing. If the coil hot is fed direct from EEC then the EEC relay may be hanging up and may be bad or require a diode. Need to see that coil circuit.
I do believe that is what is happening. The two hot sources from the solenoid are fused. The 20 amp fuse goes to the black/orange wire that connects to the ECM. The 25 amp fuse wire connects to the orange wire of the fuel pump relay. So I think what you are asking occurs.
I'm not sure where the coil hot is being fed from. It is a coil for a 1990 Mustang 5.0 HO if that helps.
Hey Lawson. Welcome back!
Yeah, pesky computers are always needing some other input from a human it seems. I forgot that you had to click on something to have it notify you. Thought it was automatic. Guess not.
Coil hot is supposed to come from the ECM in your case. Does not have it's own power source outside of the computer like it would have with a non-computer ignition.
The computer however needs three sources of power/signal from the vehicle's harness.
1. Full time power.
2. Switched power.
3. Start power.
I think the main power is to the relays only, and the computer does not get full time power. At least some harnesses must grab that from another source, because obviously the computers need power to keep the memory powered up. Perhaps this is what's going on, where maybe it's full-time power is not shutting off when the switched power is telling it to?
Switched is to turn things on and off so it knows when to cut the ignition off.
Start power (usually taken from the starter relay instead of the ignition switch) is just to tell it when to start monitoring the PIP signal from the distributor, to retard the spark timing a bit for easier spinning, and I think basically just to tell it what's going on in the outside world.
Somewhere, one of your circuits that's supposed to shut off with the key is not doing it's thing. Like Joe was saying, maybe the ECM power relay is hanging up, or one of the others. I think the main ECM power relay is the most likely culprit if so, but that's easy enough to test by rotating the relays in their sockets. They should all be the same pin orientation, but I'm not familiar with your particular harness.
Is there a bank of relays? And if so, how many? The Ron Francis harness we sell has four relays. The Painless harness we sell has only two or three I think? How many does yours have, and are they all the same type?
If they are, try swapping a couple around to see if anything changes.
And yes, keep checking for backfeeding from the alternator just in case, but the problem with Broncos is that they just LOVE to throw big fat coincidences at you when you least expect it. So while you may have only changed the alternator, some other component may have chosen just that moment to go belly-up.
Hey, it happens. A LOT!
Good luck. Got nothing else.
Maybe PM (private message in case you're not forum-centric yet;D) EFIGuy here (Garry) and see if he can take a look at your thread. He's probably been busy or he'd probably have seen it already.
He might have some insight into what's going on.
Oh, and the next time someone tries to sell you on a GM alternator conversion for your Ford (probably because it's a much better price), take a pass!%)
Hah! Kidding, but only half.;)
L
Lawson
Newbie
There are only two relays by the computer, one for the fuel pump, and the other ECU I believe. I have extras for both as my mechanic said those were the most likely to ever go bad, and they were cheap to put in the toolbox.
It's not too late to return that alternator, as long as I haven't created a mess by cutting wires too closely. What would be the simplest solution? The Ford 3G? I just saw this one I have for 66-77 early Broncos, so I bought it.
I have seen "true" one wire solutions, and the 3g that I had confused this for.
I'll read your post again more slowly and see if I can make some sense of it.
The wiring harness was posted earlier in this thread if that is helpful and that is what you are referring to.
I need to come up with some strategy here. Figure out what to test or try.
I have read that the red wire is better connected to the fuse block rather than to the bat+ on the alternator. This is supposed to be better in that it provides a more accurate of the need of the battery, or voltage running through the system.
I also saw something about picking up power from the coil ignition ON rather than what I am doing now, but I also saw something that suggested the bulb creates some resistance in the system, which is why the idiot light comes on. I don't quite get it, but it was out there.
Finally this diode stuff, but it doesn't seem like that was the case given I just cut the orange wire at one point to test if that was where the power was coming to the alternator.
So, sounds like I just get to replace a relay and all my problems will be solved.... you should have shared that in the first place.
If all else fails I'll just print this whole thing out and tape it to the side of my Bronco at OCBR and offer a reward to whoever can solve the problem! For the moment I am at least able to kill the motor with the key by using ignition power to the fuel relay. I just starve the beast of fuel. Not an elegant ending, but it works.
I'm open for direction. I would love to be able to close this episode soon. Thanks.
L
Lawson
Newbie
Are ECM and EEC interchangeable terms, or is the ECM something else?
When you refer to full-time power, are you referring to KAPWR (keep alive power)?
This could be important. Let's focus on how my battery power gets to my mustang wiring harness.
There are two wires that come from my solenoid.
The EEC power relay is spliced into the black/orange KAPWR wire with a 20A fused wire.
The Fuel relay is spliced into what looks to be an orange wire with a 25A fused wire, although based on the wiring diagram, that could be a red wire.
Looking at the wiring diagram, which I confess to know little about, there seems to be some "overlap" there. Pin 1 KAPWR connects to both the EEC power relay, and the Fuel relay.
And the same is true with the power to the Fuel relay. Pin 37 red wire goes to both relays as well? That seems wrong to me, but again, I am likely using faulty logic.
In other words, I can't use the coil hot to signal or power the alternator because I have a computer run system rather than non-computer ignition. If I understand correctly.
This is the easy one as I have an extra one that I can just plug in.
Other than that, I have and DVM and if there are things I can test for appropriate voltage let me know. Maybe I should have said this early on, but I do know that my battery is registering as "bad" by the parts store, but he said it can do that for a year. I did however order a new yellow top that will be in in the morning... if a weak battery can be problematic.
Thanks for sticking with me! This one has been a challenge!!
...It's not too late to return that alternator, as long as I haven't created a mess by cutting wires too closely. What would be the simplest solution? The Ford 3G? I just saw this one I have for 66-77 early Broncos, so I bought it.
Well, I'm not sure you have to swap back out, since I'm not sure how the alternator is actually feeding back into the system without the help of something else going on. Was just giving you a hard time about the shift to GM stuff is all. But hey, they worked on millions of GM vehicles without trouble, so not sure you need to go back to square one just yet.
But if you do, yes the 3G is one of the best out there and the wire colors match your Ford.
We sell one of those. Simple connections, but even the regular 3G is plenty simple, so the 1-wire solution is only if you really just have to keep things to a minimum.
Good luck! %)
This is true, and it's how the factories usually do it. But it's also been proven time and time again that connecting it to the alternator's output is a very workable solution. And when done right, the voltage drop between the output post and the fuse box should be very minimal.
You're basically fooling the alternator's regulator, but it's a legit ploy.
Yes, but where you're pulling from now (the Green w/red wire) is better. It's still with "ignition on" as far as the switch is concerned, but it's not connected directly to the ignition on for the old coil or the new ECM. After all, the Green w/red is where the original voltage regulator got it's power from in the first place. And does not have any potential for messing with the ignition on a standard, non-computer setup. In your case though, is anything connected to the old Red w/green wire that used to power the ignitions system?
There is no bulb in the factory Bronco setup anyway, so that part does not apply.
Yeah, confusing for sure sometimes. But don't sweat it this time since you don't have an indicator light.
Or do you? Did the installer use a charge lamp somewhere?
Correct. Diodes are to keep the power flowing in one direction only. But since you proved that there was no power feeding back to anything there, it's not necessary to go to the trouble of installing one.
Well only if the relay is the problem it will. But since it could be, and you already have a spare, there is a good reason right there to try the new one.
Uh. You mean like my first post, second sentence in the first paragraph?:eek:;)
I didn't mention the word relay maybe, but at least I got right down to business with the power stuff. You should have had it all figured out and running right then and there!;D
Inelegant maybe. But effective!
Now I have to go back and re-read how you got there.
...You are correct, the EEC gets it's full-time power from the solenoid plus. There is a 25A and a 20A fused wire going to the 86-91 Mustang harness. The 25A wire goes into the Orange wire of the Fuel Pump Relay. The 20A fuse goes to the Black/Orange wire on the ECM.
Does this Black w/orange wire go directly to the ECM, or does it go to the ECM relay?
I'll look on the diagrams and pics and links, but figured I'd ask in case I forget to look.
Sorry I kind of ignored the diagram yesterday, but I figured it would be something that was not on the schematic. Worth a look anyway though.
1. I took both EEC wires off hot and put them to ignition ON, and left the black fused wire connected to the solenoid. No go.
So far, so good.
2. I connected the 25A going to the fuel relay to the solenoid hot. And I connected Ignition ON to the 20A fused wire going to the black orange ECM. The truck would run, but not shut off.
3. I flipped the above. I connected the 25A fuel relay to the ignition ON, and the 20A black/orange ECM to the solenoid hot.
Good test!
#3 is where I saw some semblance of success. Basically when I shut off the ignition, the fuel pump quits running, so the engine just slowly dies after about 2-5 seconds. Not the best solution, but at least I can shut it off. But, going for a better solution.
So it appears that the ignition switch in the dash is doing it's job, because the pump shut off. But this test still indicates that power is applied to the ECM all the time, key ON or not. Now we're getting somewhere!
I think...
Finally, the one thing I think I need to make sure I do in all this, is to make sure that the computer memory maintains power so it can continue to learn, and not be reset every time I shut the truck off over night.
Yep. But I wonder if the memory circuit is keeping the engine running (computer error) or the power is connected not to the memory wire, but to the actual power-up wire (wiring error)?
Back to the schematics then.
Oh, and I saw in a later post the question about the initials. Yes, ECM (engine control module) and ECU (engine control unit) are industry names for the same thing. EEC (electronic engine control) is Ford's name for the systems. Such as EEC-III, EEC-IV, etc.
We use EEC to sort of describe the Ford units only, but the ECM/ECU are for the computer specifically, and are industry standard terms. Not sure which one is finally settled on, but I usually use ECM myself.
Another one that got jiggled around is IAT (intake air temperature) and ACT (air charge temperature) and maybe one other for the same thing. Not sure which one was finally settled on, but you get used to being confused for a long time with all the acronyms, abbreviations and voodoo references.
I just want to make sure I understand correctly. Is the "ignition feed source" the wire from the firewall that starts out green/red, continues as orange, and finishes as white at the alternator?
Curious too. Not sure if Joe meant the one to the alternator (the one you just described as having cut) or if he meant the one that feeds the switched power to the computer (which handles the ignition duties and can keep the engine running).
But either one is worth testing, just to make sure the ignition switch on the dash is functioning.
Even though it should not effect anything, it's still good to know whether the alternator feed (Green w/red, then Orange, then White?) is shutting off when it's supposed to. Which is sounds like it does from your other test.
But what we really need to know is if the key cuts off power to the computer with the key OFF.
But for that we need to know which wire has that function. Or just test all the wires on the back of the ignition switch.
Sort of. I should have referred to them separately, but I wasn't really thinking of the KAPWR as much as I was the main power to pass through the relays (to power the pump and ECM).
In this harness and diagram it looks like they're one and the same Black w/orange wire you're talking about. So that sounds kosher so far.
In my comment about START, RUN and CONSTANT, I was ignoring (actually I was forgetting) the KAPWR completely. For now at least that's a secondary concern anyway I think. Unless the ECM is bad, this wire should not be the cause of your issue.
So the START in my comment was Pin 30 in the engine harness up top in the diagram (Black wire?), the RUN is the wire at the bottom of the diagram marked "to ignition switch" (does not list a color) and the CONSTANT was the Black w/orange for the relays (and KAPWR).
The only thing that one wire from the ignition switch does is send 12v to turn on (energize) the EEC relay so that everything wakes up, so to speak.
By that same token though, turning off the ignition switch should completely turn off power to everything as well. Killing the engine as you would expect a normal one to function.
Your issue seems to indicate that your switched power is on all the time instead.
But does your fuel pump prime for a second or two when you first turn the key to RUN? Or does it just come on when you hit START?
Can you cause the fuel pump to run all the time by grounding the correct pin location in the TEST plug? You can see the Tan w/light green #22 wire going up to the test socket.
Sounds good so far. This is ok as long as the wire is connected to Pin #30 of the relay. Not to be confused with Pin #30 of the EFI harness.
The initial wire colors at the fuses may be arbitrary. Hard to say. But first thing to note would be that the Pump relay also uses the same Black w/orange wire that the EEC relay does. Which should also be to it's own Pin #30 on the relay.
Then note the other colors and locations.
The Black w/orange will have 12v all the time.
The Pink w/black will have power the first few seconds after the key is turned to RUN, then thereafter when the engine is running.
The Red #37/57 should only have power once the key is turned on and the engine is running.
The Tan w/light green is a ground, but only after the ignition switch is turned on and the engine is running.
You can test those by unplugging the relays from their sockets and using your volt-meter to probe the sockets. The pin orientations may be listed on the side of the relay, or molded in small numbers underneath where the contact pins stick out of the plastic housing. But you can also find the proper orientation online most likely.
The relay pin #'s should be:
Pin #30 should show 12v all the time.
Pin #85 should show 12v only with the key in RUN
Pin #86 should be grounded.
Pin #87 (NOT 87A by the way) should have no power when the relay is unplugged.
Again, these are the relay pin numbers. Not the numbers on your EFI harness diagram.
Those are industry standard pin numbers for the standard Bosch or Hella type relays. If yours is using Ford relays they may be different.
Correct. This wire is simply a common power wire from the battery positive. This is the "hot all the time" wire we've been talking about.
It's where the KAPWR gets it's constant voltage from, but is also the same circuit that lets 12v pass through the relays from the battery and on to their specific functions. With relays, just as with other switches, some wires are redundant to reduce the amount of wiring, and can power multiple things from one wire.
Maybe someone knows whether or not you can unplug the power relay while the engine is running without harming anything in the computer. 'Cause that would be a good test.
If you pull the EEC relay while the engine is running, it should die instantly. Like if you just pulled the plug. Which essentially you did.
If it continues to run, power is sneaking in from somewhere it should not be.
But don't do that until someone more knowledgeable than me says it's ok to do.
Yep, it's ok. That's the wire that, once the relays have been energized, power passes through the Black w/orange wire from the battery, through the relays and on to many things in the system. But they should by design not be powered up until the key is in RUN and the EEC relay powers them up.
Not sure myself. I personally like to avoid entanglements like that, but not sure what the factory does. Either way though, your old coil wire (Red w/green) is a resistor wire, so it's best not to use it for the alternator anyway. A resistor wire loses voltage to resistance after it warms up, so your 12v initially turns into maybe 8 or 9 volts in a few minutes. Not sure what that would do with an alternator.
But the Green w/red wire that you're currently using for the alternator is perfectly fine.
And doubling it up to use for your EEC relay would likely be perfectly fine as well.
Pretty sure that the RJM/Ron Francis harness that we sell uses the old resistor wire to power the EEC relay. I've never opened one up, so can't say that for sure. But it makes sense since a relay doesn't really care if it's a resistor wire or not. Usually...
Sounds like you still need to track down what wire from your Bronco harness is connected to the EEC relay.
Start with the relay sockets and go from there. If you run across any anomalies, disconnect the alternator and test again to see if there is a change.
Specifically hunt for a signal voltage from the key. One that is off with the key.
Hmm, they do cause lots of problems when low, but usually not a situation where you can't turn the engine off. I don't think anyway. The key is supposed to be able to shut everything down via the EEC relay.
Never run across that particular scenario, but it would not be beyond belief at this point either!
Just remember that any voltages listed as 12v in our conversation are really supposed to be "battery voltage" at the time. So if you're showing 11.9 at the battery, that's what you'd want to see at the wires. You're allowed a tiny voltage drop, but anything more than 2 or 3 tenths of a volt would be suspicious and should be looked into I would think.
The only exception to that is a signal wire coming from the computer which might show 5v instead. But you shouldn't be testing those with a standard meter anyway I don't think.
And the resistor wire, which you may or may not be using at this point.
Still the best of luck.
Hope at least some of that made sense. I think I started this at 11:30 but kept getting sidetracked scanning old family photos into the computer.
Amazing what memories and feelings that 100 years of family photography brings out.
Joe473
Paul, I didn't realize this was a GM alternator. I saw this exact scenario happen on a Chevelle after a pertronix install. Pertronix kit came with ignition relay and car wouldn't shut off. Basically coil of relay would energize and then would not de-energize on key off. Removing Orange wire should have proven this was case. Pertronix instructions on GM was to add diode in coil circuit of relay so stray voltage backfed through idiot light would not keep it energized. It wasn't full voltage was only 7 volts but enough for relay hang in. Pulling trigger wire would let it drop out until next start.
I think there may be a second problem other than orange wire created with swapping of feeds/troublesshootibg keeping that ecm relay energized or ecm fed.
I agree EFI guy is a great resource to ask. Any of us would need you to verify all wiring around that ECM relay and ignition and mark it on drawing.
1 other thing I noticed is the wire on the I terminal on the solenoid/relay. Where does that go in this hybrid harness and is it needed? I have seen cheap solenoids/relay short that to ground and still work to engage starter.
Also if I understand what was done with fuel pump I would undo it. The main feed for the relays should come off battery. Your switched ignition feed to fuel pump will not handle current draw of pump and other ignition accessories. What that does tell me for troubleshooting is that something is keeping both those relays coils partially energized.
Sent from my SM-G900V using Tapatalk
L
Lawson
Newbie
Wow! I was hoping that I at least got a "Good Luck with that!" response. I just started reading, but I'm sure I'm going to learn a lot... in the process of solving this... I hope. Onward, but thank you in advance regardless the outcome.
The ignition ON power comes from the wire that was originally going into the voltage regulators S position. That wire was then connected to the regulators F position orange wire that originally went to the back of the alternator. Essentially, they used the orange because it was there. The S wire is faded, but looked to be green, or light green and red. Maybe this is key? Take a close look at this photo. The easily identifiable green wire comes from the firewall and goes into that plug. It comes out the other side and went to the regulator, but the color is either badly faded, or maybe completely different. Thought? Perhaps I should pick up the connection where the wire is truly green, and not from the alternator side of that plug. After all, that plug goes to the fused always hot starter solenoid. I'm so excited I'm going to post this now before I go on! :)
https://outstandingscreens.com/Bronco/IMG_1222.JPG
L
Lawson
Newbie
It splices to the wire about an inch from the ECM relay, if the relay is that little brown box looking relay thing... I can investigate the specifics if needed.
I guess in my mind, the key does not shut off power to the computer. The computer is under constant power from the two fused links to the solenoid, as I interpret what I see.
Historically, yes I always listen for the pump to prime before I start out of habit. I can certainly go to the TEST plug and try what you are asking. I'm not sure the procedure. Like, ignition ON or OFF? And "grounding to the "correct" pin location. Just give me direction if you think it is pertinent.
I can certainly investigate all of this, but my inclination is that things should be good as I have been running this system for at least 10 years. My original installers had some "issues", but I have since gone through about everything under hood and double checked the work, with the exception of some of the specific pins to specific wiring in these relays. I knew enough to be dangerous, but tested what I could read about. Made sure connections were solid. Cleaned contacts and such. I didn't realize that the relays had corresponding pin numbers. But in short, all of this can be looked at more closely, but seems a complex direction. At that point I'd rather just buy a 3G and start from there! Lol. May end up with the same problem, but at least it would be a more traditional approach.
Uh Oh... Lol. I believe the EEC power relay is what i was using temporarily to shut down the truck for a day or so. And, yes it does shut down the engine, and doesn't appear to have harmed anything. I would just reach across to the glove compartment and unplug the relay. I don't do that anymore, but I certainly did.
This was a response to my "I've got a DVM" comment. Would I do all this testing with the engine running, or with the ignition ON, or with ignition OFF? My guess is it depends on what I am testing, and what I am seeking to learn, so the answer is, "it depends." But if you have a specific procedure, or something you suspect, I'll jump in.
JOE 1 other thing I noticed is the wire on the I terminal on the solenoid/relay. Where does that go in this hybrid harness and is it needed? I have seen cheap solenoids/relay short that to ground and still work to engage starter.
I'm not sure if this answers your question, but in my first "panic" moments of trying to shut down the engine, I pulled the ground from the battery and it kept running. The next two nearest items were the I and S plugs on the solenoid, so I pulled them as well, and the engine kept running. That is when I went to the EEC power relay and unplugged it, and that caused the engine to stop.
I think I have what you are asking. Both feeds to both relays comes "off the battery" in that they come off of the solenoid positive side. I don't think I have a switched ignition feed to the fuel pump directly. Certainly not something I wired up. Like you, if I understand correctly what you are asking. Thanks.
Thanks again. Hopefully my answers are somewhat helpful. I need to clean up my wiring some, and get my new battery picked up, and get the bronco ready for some work today... whatever that may be. Probably won't need the welder, but a few connectors at the parts store may be a good place to start.
L
Lawson
Newbie
I'm still hoping for an answer to the question about using the "green" wire on the firewall side of the plug rather than the alternator side of the plug. Think it will make any difference?
And, if I wasn't getting ignition power to the alternator, what would happen? I have tested the wire, but if for some reason the power wasn't making it all the way down into the contact on the alternator, what would happen? Battery would die? Truck would die? I'm just trying to confirm that I am getting power into the contact without having to remove the alternator to test it.
I'm just looking for my next steps here.... thanks.
...I guess in my mind, the key does not shut off power to the computer. The computer is under constant power from the two fused links to the solenoid, as I interpret what I see.
Yes and no. You have TWO separate circuits that are powering the computer.
The only one that is constant is directly to the computer via the Black w/orange wire at Pin #1 on the EEC connector. This is for flash memory only and does not "power the computer" or anything else. Just keeps the memory alive as far as I know.
The real power though, the one that must be key-controlled so you can actually turn off the engine, is Red #37 and #57 to the computer from the relay.
It's the relay that is switched on and off by the key, and then powers up, or powers down the computer. Without that being switched to the computer, you would not be able to shut down a running engine. And on top of that, you would likely drain your battery overnight due to more circuits being active. And on top of all that again, you might even burn out your ignition coil or other things from being powered up and overheating.
So there MUST be a switched computer circuit or you will have the same exact problem you're having now.
So, constant power is only to two places. A small amount goes to memory, and the rest sits there at the two relays waiting for the switched power to tell them to wake up.
Or go to sleep, as the case may be...
Not sure if it is or not, but it's one more thing that's testable. And I'm not sure the procedure anymore. Someone else can chime in on that.
That's what I keep coming back to as well. If literally the only thing you've changed is the alternator, then that's what would seem to be the only culprit.
But then why didn't it shut off when you cut the Orange wire? Maybe because this type of alternator continues to put out current even once it's disconnected? I don't know, but that's why I suggested you pull the 2-wire plug, then start the engine. Once running you should measure voltage at the battery to make sure it's just static (around 12-12.5 volts) and not charging.
If not, then turn the key off to see if it stops. If it does, you KNOW it's the alternator. Then it sounds like it's time for a diode even though it passed the previous "cut wire" test.
... But in short, all of this can be looked at more closely, but seems a complex direction.
I agree. If it worked before and you didn't mess with anything, then leave it and concentrate back on the alternator alone.
Well, there is that. Was not aware that this GM alternator "thing" was such a thing.
Ok, well at least that proves that power is getting back to the relay and keeping it active. Once disconnected the engine dies just like it should.
So back to the energizing wire of the relay and why it's not turning off with the key.
Kind of leads back to the alternator and where the EEC relay is getting it's switched power. Must be feeding back.
This is consistent with the alternator charging. While it's doing this, it is the power source for the system. Not the battery.
So disconnecting the battery does not get rid of the power source. Although it should play havoc with things, but sometimes doesn't act like you would expect.
Sounds correct as well. The "S" wire's only function is to energize the starter relay and crank the starter.
The "I" wire should no longer be connected to anything because all ignition duties are now handled through the computer entirely.
Good to know. Now we know that you are able to shut power off to the computer through the relay, which is somehow staying energized and keeping the switch contacts closed and the current flowing.
Yep, fuel pump relay should be "switched" by the computer only. Only the EEC relay gets switched by the key.
I think we're getting somewhere now. Pull the plug on the alternator and start the engine again. Don't worry about it not charging for a bit. The battery can handle (assuming it's fully charged?) those duties for quite a while. And you only need a minute to test the theory.
L
Lawson
Newbie
The test being? Lol. Two things. I don't know how to check voltage, I mean I have an idea. The other big downside is that this setup has the plug right against the bracket. If I'm just disconnecting the white, or ignition source, then I can do that from the orange wire. If I have to disconnect all wires, then I have to do a lot more work. I would appreciate some guidance going forward, and any thoughts on that ignition source either before or after the plug? Thanks.
The test being?
The test being, does can you turn the engine off with the key.
You said you had a DVM (digital volt meter?) so I figured you could use that.
If you're not sure how it works, post up a pic of it and we can walk you through it.
Basically though, most volt-meters are similar. There will be a switch or a dial that you can turn the pointer to something like: "VDC 20" or just "Vdc" if it's auto-ranging (can handle all ranges of DC voltage).
Red probe to positive side of battery, Black probe to negative.
Usually the wires are either permanently attached, or allow you to put them in multiple holes on the meter. The Black will go to COM and the Red may push into a hole marked "V-Ω-mA" or something to that effect.
I was just wanting you to test the battery voltage with the engine running to see if the alternator was charging anyway. If the voltage reading is 14.5 volts for example, the alternator is charging.
Then just disconnect the Orange/Green w/red wire. That's the only one needing testing anyway.
Good luck.
73azbronco
What,kind of starter and wiring for that do you have? I seem to remember another thread years ago with a mini starter feeding back into the coil
Yeah, we were wondering about that. But he said he thought it was a basic stock old style starter.
But if you can get a pic of the starter too Lawson, just for giggles, that would make certain.
L
Lawson
Newbie
DVM - I have one, I have used it, and I will look up how to test voltage on a battery or at other points. I just have to remind myself of process before I use them. I'm not going to make you do all the work! Ok, that was simple. Quick couple YouTube videos. I think I'll test some ground continuity while I'm at it as well.
That provides some clarity as to the 20A fused wire going to the black/orange. Clearly this is my source for KAPWR. That makes some sense.
This is not a mini starter. Same physical size as 75 Bronco.
Ok, digging out the DVM freshly armed with some things to look for.
And has this been given any consideration?
So, is this my problem? I'm going to the alternator from the light green/red wire on the alternator side of the plug. Should I just the plug and instead connect to the green wire on the firewall side of the plug? Any difference?
https://outstandingscreens.com/Bronc...izeRender4.jpg
Fingers crossed..
Photo of the starter? I was looking for an oil leak the other day by taking some photos, so let me see if I happen to have that image... just for giggles. Found one, it's in the background there, but enough to answer the question I think.
https://outstandingscreens.com/Bronco/IMG_1139.JPG
https://outstandingscreens.com/Bronco/FullSizeRender4.jpg
The link in the most recent version of this question does not work for some reason. I went back to your original post higher up the page for this quote.
There's really no way for us to tell from here if that plug is causing any trouble or not. If that's what you meant?
We did discuss it a few days ago, but not at length. The Green w/red wire is for the alternator. No reason to think it should not be used in this case.
And if it's in good shape, then there's no difference between the body side and engine side of the plug for the Green w/red wire. It's a discrete circuit all the way from the ignition switch with nothing else connected to it. It's specifically to power up an alternator regulator. Which is exactly what it's doing with the new alternator.
What is it that you're seeing that you think might be a problem?
If there's some condition I can't seen in the pic, then you'll have to diagnose it there. Frankly, much of your wiring is looking like it's seen better days. Practically every picture shows either a kinked, cut, sliced, spliced or otherwise damaged wire. I can't even imagine reusing that Orange wire from the original harness just because it was there. Look at it near the back of the alternator and it's in such bad shape that, even though it might be conducting electricity now, it's day's are numbered in a real-world environment.
Even at the connector in question the main power wires are so bent, crushed and crimped that they should not have been able to handle the power of a fully charging alternator. The fact that they did is testament to how good some things are made. But again, would have been on their last legs for a vehicle that was driven very many miles. Luckily Broncos don't get used as high-mileage daily drivers very often. Most of them have wiring very similar to yours in fact. My buddy decided he wanted to keep the wiring in his '77 when we installed a Ford EFI engine in it. The first time we tried to move a wire the jacket cracked. The first time we tried to splice one to one of the new wires, it literally broke.
Obviously, a complete new harness went in before the EFI did in his case.
If your wires are still holding up and in good flexible shape, that's great. But any of them that have been rubbed the wrong way, or bent to the point of kinking, should be looked at closely if anything ever goes wrong electrically.
Maybe that's what's at play here, or maybe not. But it needs to be kept in mind in the future when diagnosing trouble.
Now, back to the easy test. Have you fired up the engine with the Orange wire to the alternator disconnected yet? What happened?
