Hmmm. One little caveat. When I start the truck, the red light next to my key does light up.
You mean the one marked "BRAKE" by any chance?
Aren't you saying that shouldn't happen?
Don't know. If its the BRAKE warning lamp, it's exactly as it should happen. Only during start does it self-test, then goes back out. If it comes on while driving, you have a leak or other imbalance in your brake system between the front and rear lines.
Or that if my alternator has problems in the future, I won't get that light.
Let's see the light first.
I'm good with either. I just want to make sure that leaving that disconnected isn't doing to harm anything, or over-charge the battery or some such thing.
It's not so far, from your testing. That 14-something volts is just right. You should always see between 13.5 and 14.5 (or within a couple of tenths of those) when the engine is running. When it goes above or below that is when you need to get to digging for trouble. A volt gauge in your cluster or on your dash somewhere else is a necessity with your setup. Or a light.
There are aftermarket digital gauges that simply plug into the cigarette lighter that let you monitor your voltage at a glance. Very cool actually.
There are also similar ones you drill a hole for, for a more permanent mount.
I'm not aware of any harm in leaving the one wire disconnected if everything is working. But again, not being a GM alternator person, hopefully someone will join the conversation that is and can tell us both.
7278F-6-135A-3 WIRE-12SI PLUG-SP - Given the part number of the alternator, it would appear to be a 3 wire....
Yeah, but here again it might be that we're not on the same page as the GM engineers. Maybe that third wire is not needed for anything but the dash indicator lamp. That we don't have...
If it's needed for telling the alternator to turn on and charge, well, it seems to not be working and you should call the seller for clarification.
If it's only needed for the light, then you should not have any trouble. But carry your newly powered up volt-meter with you!
This way you can sneak a test in now and then when you stop for gas and your family is none the wiser. Or upset about how much attention you're paying to your Bronco!
Now about that non-ammeter Ford wiring setup, you are out of my depth on that comment. I'm wading pretty shallow as it is, but let me make this possibly embarrassing statement. Are you saying that this alternator was for a 66-77 Bronco as advertised, with 66-77 wiring...
Don't know for sure. Maybe they (the seller) just isn't aware of the difference in regulator wiring in Broncos. Would not be the first time.
...but since my vehicle is a "hybrid" using a 1990 Ford Mustang harness and electronics, the 66-77 rules don't apply?
Nope. Not at all. The engine harness is always separate entity from the chassis/body harness, and can work with anything. We just always have to differentiate between the two. But in the case of the charging system, it's usually at least considered mostly to the body side. They just happen to sometimes have a common connector. IN our EFI harness we have an alternator exciter wire (the infamous Green w/red!) already built in to the engine harness. That's just to keep things clean though, and so you don't have to run your own. It still plugs into the stock body harness behind the engine, but is taped up in the engine harness for cleanliness.
By "non-ammeter" I was referring to something that Ford themselves did. Some Ford vehicles (cars and trucks) use lights only. While others (such as all Early Broncos) use gauges and no lights at all. So while a Mustang of a certain year, or a pickup truck of a particular option package, might have just a battery/charge indicator light, we have an ammeter.
In the two cases, the voltage regulator is wired completely different! Even most shop mechanics don't know, or don't remember that. We've seen many a shop mis-wire the regulator because they were more versed in standard Fords, and may never have even worked on one with an ammeter and the different wiring scheme.
So we have our 3-wire regulator harnesses, and they have their 4-wire regulator harnesses. And never the twain shall meet...
I'll buy that? Why not, after all, it's working and I have to get packed and ready for a trip! I just don't want a battery bomb to go off as I saunter down the highway. I'm confused in how a battery charges, or knows when to charge, or how it doesn't overcharge. But hey, who would question a gentleman with the name of DirtDonk? Lol
Haha! Get to packing there guy!
