antonm
So, I recently picked up my 74 Bronco that the PO said didn't run. Well, I got it to run, but when I turn the key off (and remove the key from the ignition) the motor just keeps right on running. I pull the power lead off the coil to shut it down. While I'm planning on converting it to EFI and doing a full wiring harness anyway, I'm still kinda curious as to what this could be. Is this a common occurrence? Its a factory 302 /C4 right now.
