You are already running unleaded, not the original fuel. E10 will be fine. Storage with ethanol is not a good idea. Moisture compounds the issue. Why you probably had issues with the outboard. But as long as you are using the vehicle it isn't the horror that you get from storing.
As for the rubber. Good modern rubber is immune to it. Old rubber, this could be the final straw. But you should replace anything that close to the end of life anyway. The good rubber is hard to find. For the most part rubber hose is stocked based on how cheap can it be bought. Stuff like marine barrier hose is harder to find and more expensive, but holds up.
In short, road trip no problem.
