Ethanol
Slowleak
Georgia
What a mess! Yikes! Is that from ethanol? I noticed the other day that they are saying that ethanol emits more bad stuff into the air than gasoline.... Crazy!
Yep, Ethanol…. It ate up the sock filter and clogged the pump and injectors. I’m lucky that it is a plastic tank. The tank cleaned up and I ordered a new pump.
Timmy390
Conway, AR
I'm not kidding when I say....only non-eth in my 4 wheeler. It sits from one deer season to the next. It fires right up year after year. Heck I don't even put a battery tender on it. The new AGM's seen to not loose charge over the long sit.
Tim
Slowleak
Georgia
Nothing but pure gas for me from now on. My next UTV will most likely be a diesel. I let my Ford 3000 diesel tractor sit for 3 years once full of fuel. Put a battery in it, turned the key, and I don’t think I even heard the starter….it fired right up. It’s a Ford!
Glass Pony
Sussex County Delaware
I've been running E10 in my carbureted Bronco for the last 9 years. As long as I am using it at least weekly, I do not run Stabilizer.
Once the weather starts getting cooler and I am using it less I'll start running the Stabil Marine product.
So far so good.🤞
bmc69
Well, my Polaris Ranger wouldn’t start this morning. Pulled the tank and found this mess along with about 1/4 inch of sticky sludge….
I pulled the fuel pickup assembly from the plastic tank on our jet ski and it looked like that, only worse; the lower part of the two pickups were eaten clean away.. We can only get non-ethanol gas at marinas around here, which is quite inconvenient.
green61bug
Greensboro
I run ethanol gas in my bronco most of the time because I'm driving it so regularly... I pretty much only put non ethanol in my yard tools... Now that Im saying all this Im thinking about all the vehicles I havent cranked and ran in quite some time...
It can be bad, but is not guaranteed bad. Getting water in a fuel system, regardless of ethanol of not, can be very destructive. There are plenty of other additives that go into fuels these days that do not age well when stored.
That said, my stuff that sits for long times gets good gas. I get a couple gallons of 110 race gas and mix 90:1 2-stroke for my motorcycle. That goes in all my small engines, 2-stroke or 4-stroke. The boat gets 100 LL av gas, the local airport manager gave me the gate code so I can fill up at the pump.
Stuff that gets driven on a regular basis, whatever pump gas is available. Doesn't stay in the tank long enough to be an issue.
fordfan
We do a lot of work in the convenience store and fuel center field, and almost every tank/lines/dispenser service tech and maintenance guy that is on site when we are, is working on something cause by ethanol! Many of them express extreme frustration at all the issues caused by ethanol! The buildup and sludge in the in-ground tanks stop up the sumps, fouls the pumps, and causes dispenser issues, so it's not in just something that sits too long, it's a problem in anything! I can drive by a petroleum tank farm (storage tanks at an oil terminal) and ,from the road, I can tell you which tanks have ethanol stored in them!
A year or so ago, the State of Florida had a class action lawsuit against oil companies and ethanol fuel because of the marine industry, and all fuel in Florida would be gasoline, but I haven't kept up with it... I guess it's ethanol there still.
Everything I have except the daily drivers gets just gasoline unless its a diesel.
blubuckaroo
Grease Monkey
Ridgefield WA
I've had the same Edelbrock carb running on it on ethanol for over twenty years. I opened it last year when I was calibrating it with my new wideband gauge. The carb was perfectly clean inside.
Also, the fuel pump is older than the carb.
The problem with ethanol is storing it.
Buy your gas at busy stations only.
I do use non-ethanol in my power tools. They might not be run for months.
