jimschulz
I am finishing up my 5.0 EFI explorer swap and have a question on installing the Cam Position Sensor. The manual says to install with the arrow on the clocking tool facing the front and parallel to the engine center line. I have #1 at TDC of compression, and when I stab the sensor it is either to the left 10 or so degrees or right 10 or so degrees. There is no way to get it to point straight forward without removing the clocking tool, which I know is not what I want to do. Is it fine to have a slight clock left or right as long as the tool has the body lined up? Thanks in advance!
