A little bit of an update, got my 23 gallon tank in that was creatively decorated by the NorCal crew for me...and yes I plan to leave it on there.
Took the Cam sensor out...oops, forgot pic, I'll get it. I was going to take the gear off of it and put it on the Mustang dizzy I had but I couldnt get either gear to come off and couldnt find my drift so I just put the Mustang one in, I am 99% sure its a steel gear. I have it pretty close to #1 setup, close enough to play with it once it is up and running. With the TFI module on there and the filler neck and the serpentine brackets there is not much room for adjustment so be prepared to re-stab it to get it right.
Got my fuel rails basically ran, just need to mount the pump and connect up to the tank. I am having serious issues finding a pump that I can put a fitting on to go to -6AN, not fun. I have 1 other pump I am going to try since the BC pump (f250 I believe) has a 8x1.0 fitting, the 2p74028 (f150 napa line) has a 3/8x24 thread which doesnt seem to exist either. I need to find an EP7109 still (the original part number for the 2p74028) as it is rumored to be 10x1mm which I actually have but the pump doesnt seem to be stocked anywhere.
Mounted the coil on the inner fender, not sure if it will stay here but the holes were already there and the wiring seemed to fit right there. Had to get the coil bracket at the yard, got it off a 90 Bronco with 5.0.
Got the Barometric Pressure sensor also mounted. I'll have to figure out where to hook the vacuum to on it.
Installed the BC EFI throttle cable, that was a PITA. I am using some explorer stuff so that didnt completely help but the bracket had to be trimmed to fit the throttle body and the instructions have you flip the Idle Air Bypass but if you do that plan on cutting into your $500+ harness as the pigtail wont reach. Ended up drilling another hole in the bracket about 3/4" in to put the cable to. The spring that comes with the kit did not work right and even in the correct hole (tried that first) it was too high of tension and would just distort not allowing full throttle. Trimmed the spring and still didnt work right. I'll go find another spring and put it on the other side of the fulcrum as a puller instead of a pusher. The rest of it went together fine but drilling and grinding on new parts never feels very good
