- Apr 28, 2017
- 529
Just about everything needed to convert a 302 to Explorer EFI with Explorer front dress
All items removed from a 1996 Explorer 5.0 with approx. 130k
• GT40 Upper and lower intake with fuel rails
• Throttle body
• Mass air meter
• Alternator Bracket with remanufactured alternator and original tensioner
• Power steering bracket with pump reservoir and pulley
• 50oz harmonic balancer (may need rebalanced depending on application)
• EGR elbow and exhaust manifolds for emissions
• Metal Fan with fan clutch
• New water pump (used for mockup on a different engine)
• Cam synchronizer
• Reverse rotation timing cover
• Coils and mounting bracket
• EFI valve covers
• Heater lines
• Complete wiring harness with computer, Inertia switch, OBD connectors stripped and ready to go to EFIGUY to be modified
• Toms Bronco parts reverse rotation aluminum radiator with modified full circle fan shroud (approx. 500 miles on this combo)
• The only thing I think is missing are the injectors. Will need a set of 19lb injectors commonly found at any wrecking yard. Maybe a sensor or two as well.
$750.00 for everything OBO
Local pickup.
• Throttle body
• Mass air meter
• Cam synchronizer
• EFI valve covers
• Heater lines
Local pickup.
