I'm text fitting the engine harness tonight. And I have questions for those with this experience. In this picture does the 1-4 cylinder side of the harness. Go under the hard coolant tubes and the top edge of the valve cover?
Next question. The large diameter cable from the ECU is loomed into the harness between the #3 and 4 injector connectors. Is this the proper layout?
If so, how did you deal with its placement in this area?
