Explorer serpentine alternator compatability
amfw
Im continuing the process of going through my newly acquired rig, and have gotten past the stuff needed to get it on the road. Im not sure where my first stop will be, but I am thinking forward to the Explorer serpentine setup.
My question is about alternator compatability. I have a NIB Powermaster 8-47140 150A alternator.
Would that be something that would work or could be made to work relatively easily with the Explorer setup?
If its a poor fit, I don't have a desire or need to shoehorn it in. I just want to know if i should try and pass it on and find a new one, or hang on to this until I do the Explorer swap.
Alternator is 150A, 6 groove, one wire.
thanks for any info
bronconut73
Explorer alternator is pretty unique.
Can't imagine mounting any other alternator to it.
But you don't need to.
DB electronics on Ebay has an Explorer 140 amp new replacement for about $100 bucks.
The stock Explorer alternator is like a 130 amps.
Good stuff.
Even the stock ones can put out 140a sometimes. No guarantee of course, but I've read enough of the rebuilt alternator performance check sheets to see that they usually put out more than the rated amperage, and often 10-20 more.
As said amfw, you're out of luck making that one fit an Explorer bracket. It uses what is called a "side mount" alternator that looks nothing like a regular alternator's mounting points. It's very stout and very well designed, but is not conducive to swaps.
Which version of the Powermaster do you have? That number lists out in a search for anything from a converted GM 1-wire to a large-case 1G externally regulated unit!
Something must be missing in my search ability, but they all showed the same part number.
Neither here nor there though, as none of them are compatible with the Explorer.
Time to put it up for sale then and recoup some of the original cost. Or better yet, look at it as recouping some of the cost of the Explorer upgrade.
amfw
amfw
The alternator I have was for a '88 econoline with a 351w. It's not a big deal that it doesn't fit, just good to know. I appreciate the replies from both of you. As I'm sure you know, part of being a car guy is also being a part (full) time parts seller/manager haha. So sounds like this one is gonna get sold, and that money will definitely be going towards the explorer setup!
pbwcr
Save yourself a huge headache and buy an Explorer specific alternator. They do not cost much.
From my notes
Alternator needs narrow foot = 55mm. w 10 mm holes
I measure 2.25” = ~57mm
Not 3” =75mm w 10mm holes
Lester Nos: 7786, 7787
Side Mount, 55mm Narrow Foot, 142mm Stator Diameter Case
3-10mm mounting holes
Used On:
• (1996-1998) Ford Windstar 3.8L
• (1996-1999) Ford Taurus 3.4L
• (1997-2004) Ford Explorer 4.0L
• (1996-2001) Ford Explorer 5.0L
• (1998-2004) Mercury Mountaineer 4.0L
• (1997-2001) Mercury Mountaineer 5.0L
DB electrical # AFD0045
The quick answer...
No, that alternator is not compatible with the Explorer accessory drive.
Question answered.
Back to the regular scheduled "what could be done" answers.
