Explorer vs edelbrock
chuck1022
I am always on the lookout for a cheap explorer for a donor.
I never put 2 and 2 together...but if I get tired of looking...it looks like I can buy an Edlebrock rpm II intake...throttle body And injectors and recreate the Explorer motor.
Am I correct on this?
Tiko433
I know just enough to be dangerous
Bolivia, North Carolina
Yes .... it would work... I’m not sure about the height, it may be the same size . I have see guys on here use them but not sure about the hood clearance
stout22
Athens, AL
I talked with Jim Creel (Wild Horses) about this during Super Celebration last week. He is going to do some measurements and figure out how the Edelbrock works with a stock hood and stock vs body lift.
904Bronco
San Martin, CA
I am going to give you something to think about... Having just done a Holley Sniper install on a 79 Trans Am, Pontiac 400 with a Tremec 5-spd behind it.
There were problems with the new unit, I spent conservatively 6 hrs on wait to talk to Holley Tech's, hung up twice after 1.5 hr waits, spoke with 3 of them in total, over the course of 3 weeks. I data logged with the unit, bought an SD card reader so I could send them data. That email went unanswered. (I have shortened this 3 month ordeal to this small paragraph) Finally the 3rd Tech I spoke with, on a Saturday, with a 40 min wait, when I started my call directly when they opened... After reviewing everything I had done or was asked to do, agreed with me that the IAC was bad, since I could not get the Sniper to idle at less than 1,100 rpm. Rather than send me a replacement part, He sent me a complete replacement unit that took two weeks to arrive.
So I say all this because once you buy into someones EFI unit, you are locked into them. No going to the local auto parts store for replacement parts, No putting on a scanning tool to see whats going on, No EFI guy, with a remote check, no going to the Ford dealer as a last resort, not putting something out on Classic asking for help. You might find a shop that has installed a number of units and is willing to tackle the problem, but what is their hourly rate?
I am not saying anything bad about Edelbrock's unit or Holley's for that matter... I am sure that there are many units that have been installed without issues??? But when things don't work, you are stuck dealing with whoever you bought from.
The end of my story... my good friend who trusted me with this project drove his car home over two weeks ago and is all smiles. I on the other had don't plan on doing another one of these conversions...
C
chuck1022
That's a really good point. Being able to go to NAPA and get parts is a huge plus
bigmuddy
Marthasville Missouri
Exactly why I am staying with the SEFI mustang or Explorer conversions. Parts and knowledgeable people all over the place.
jmangi62
I've had nothing but problems with the FiTech unit I bought. They supposedly had everything updated and ready to go so I installed it and still problems. Truck wont stay running, it hiccups and sputters as if its not getting any gas. Oh here we go again, I just can't get a break with this thing. :cry::-[:mad:?:?
BanditBronco
Yes, you can easily piece together everything needed for a explorer style fuel injection with aftermarket parts/stock parts. Only two things you can't get are the harness and the computer. Not sure, maybe you can buy a harness and ecm direct from Ford. I have never tried.
trailpsycho
Should be able to find donor parts. EFI GUY is your friend. He has videos for the DIY-guys who want to take on the harness re-work themselves, but also can perform a harness rebuild for you and help with a tune, if necessary.
He is also one of us, building his own Bronco, helping local friends on work days...a true Bronco-guy and a really good mofo.
If you arent sure, do a search for him on here. Good people. Busy, but good people.
BanditBronco
Correct, but you have to acquire said harness before you dig into having Garry redo your harness or do it yourself. The OP was asking if you could "buy" everything instead of parting out an explorer. The answer to that question is still un answered. I haven't heard of a Credit Card solution for the harness side. No one makes a swap version, does anyone know if you can buy a new one from your Ford parts department?
904Bronco
San Martin, CA
As with many Explorer parts, they are becoming obsolete due to age. PS reservoir, steel oil pan/pick-up being some of them. Having not asked for a harness, my expectation is that they are not available for at best a 19 year old rig.
Secondly, most dealerships can't talk to you unless you have a Vin number. The days of having a "old School" parts guy/gal are gone. So you would have to base your request off of an existing vehicle or one you parted.
And even searching for specific pins for certain connectors, like the factory fuse panel, the companies that rehab factory harnesses don't always have access to them. Meaning we can't buy them either.
