Hi, you should post your numbers if you want an opinion(s). Are you happy with the handling?
After my last axle swap and 3 1/2 lift upgrade I set the toe in the driveway and drove it for a few years. The handling was OK, and the tire wear was even. After getting new BFGs because of dry rot cracking I figured I'd get the alignment numbers. A guy I've known for a long time put it on a modern John Bean alignment rack and here are my numbers in degrees:
Left caster 3.9 Right caster 3.4
Left camber 1.9 Right camber .8
the only easy adjustment is toe, and my drag link allows left and right independent adjustment. First numbers were:
Left toe .12 Right toe -.1
So I had virtually 0 toe. After getting the recommended toe setting in degrees from a member on this site, we adjusted the toe to:
Left toe in .15 Right toe in .15 degrees.
It's hard to tell if it handles any better, but it is still good for and old Bronco. I'm glad I got the numbers and I'm glad I got the toe dialed in, equally left and right sides.
The recommended numbers in my Chiltons Manual is:
Caster 2 3/4 to 4 1/4, preferred 3 1/2 positive.
Camber 1 to 2
Toe in 1/16 to 1/4 inch
Good luck
