Prime Time
- Oct 17, 2017
- 30
I recently installed dual FF dynamics 8" pusher fans, and took my 75 out for a test run and after I got back I noticed I didn't have tail lights and instrument panel lights , Its not a fuse , I found that when I pull the light switch to running lights,, nothing , then pull the switch to headlights the head lights come on but no tail lights , but in-between clicks on the switch positions the tail lights will come on but not the headlights , Does anyone have an idea if it could be the switch that could be bad ? seems ironic that the switch would go out as I installed the cooling fans , I disconnected the fans to make sure, and same thing, Hasnt been hot enough to see if the dual fan idea works , I will report back on that, thanks guys
