Faulty NP435 adapter
Viperwolf1
electron whisperer
I'm rebuilding a T shift D20. Background info is it was fine behind the original 3 speed trans. After the 435 was swapped in it developed a tendancy to pop out of rear high. Upon teardown it was obvious the rear shift fork had worn into the rear sliding gear about .070". Usually this happens when bungie cords are used or when the shifter interlock plate is mis-adjusted. The constant pressure on the shift rail pulls the fork into the gear. This looked more like a symptom of a temporary fix than the actual problem itself, although it will eventually make the problem worse. The splines on the input gear (where the sliding gear meshes in direct drive) also had a strange wear pattern. Probably because the sliding gear couldn't move forward enough.
Further cleanup revealed something odd with the 435 adapter. Looking down from the tcase end the 435 plate appeared to be off center. So I put the spud shaft together with a new bearing and set the adapter up to rotate on the spud shaft. Then I could clearly see the mis-alignment. With the holes being off center the spud and rear output shaft will not be aligned and I think that is the real problem. Here are a couple videos to illustrate the problem.
http://www.youtube.com/watch?v=JW8nK_L2j8I
http://www.youtube.com/watch?v=Uw0V-nbcAak
I'm going to replace the sliding gear, fork and input gear, finish the rebuild and recommend either a new adapter or having this one repaired. I don't see a problem with cutting the 435 plate off and having it welded back on, straight and centered.
What adaptor is this?
AA? plate with an I6 housing? welded housings? something else?
Viperwolf1
Viperwolf1
electron whisperer
Looks like plate welded to 6 cyl adapter.
I think that is a plate welded to a cut down V8 adaptor. The plate and I6 adaptor are a bolt together combonation.
shamu
Lucky as the day is long.
Sachse,Tx
Here is the correct I-6 intermediate housing. I will sell it.
Viperwolf1
Viperwolf1
electron whisperer
A little update.
Adapter is at the machinist. Should be an easy fix.
Tcase is rebuilt and ready to go. I ended up replacing input and rear sliding gear, front bearing retainer (cracked on one ear), rear shift fork (someone modified it with a grinder), fork and all the bearings. It will be a very nice working D20 now.
Viperwolf1
Viperwolf1
electron whisperer
That's one of my April fools edition carbon fiber plates.;)
