Favoriite Bronco height
johnbeck
I have to get new shocks. Looking at my side profile, my 47 year old coils need replacement as well. The "nose" is down more than I like. I don't know the point of reference most used but I'm thinking a starting point guide would be a straight line across the length of the bed, extending the line out past the front bumper. I installed a One inch body lift, just replaced the rear leaf springs with "stock" Wild Horses 10 leaf pack. I have 235 75 15 All Terrains. From the side profile I haven't done the string line but I measured 46 inches at the front axle and 50 inches at the rear axle. All that said, I wish the space between the top of my rear axle tires and the uncut fenders was back to the stockish distance of one inch instead of the after l1 inch body lift distance of 2 1/4 inches. I hear of some removing a leaf spring(which one?), but don't know what the total consequences would be. Bottom line - stock rear tire clearance of about an inch, get rid of the front end raked look. Side note; I need shocks to drive the Bronco. Likely going to cost me, bottom line, $500 for Bilsteins 51"s. I need the shocks today but I don't want to throw them away when I change the spring heights some time within the next year when I have time. Any thoughts? Thanks, John B
rguest3
Both the original Coils up front and rear leafs would have sagged a lot by now.
You've replaced the rear springs but not the front yet? Replace the front coils with new stock height Coils, C-Bushings and radius arm bushings and the front should come back up, close to level, with the rear. While you are at it order the Bilsteins, if that is your choice, at the same time.
Is your Bronco at full weight right now John? Hard top, gas tank, any regular gear, etc? If so, to find out if your rear is a little high right now (new springs) you need measure from the top of the axle tube to the bottom of the frame rail. For the rear you want near to 6" or so. Give or take a half-inch or so.
If you are above that, your rear is a little high, but may come down after some use. More on that later...
If the front is lower than 7" or so, then you have sagged front springs. If it's still at 7 inches or just above, then they are still at or near original height. Get coils accordingly.
But at least at that point you'll know how your front and rear ends sit with regard to "stock" which was never etched in stone anyway. Just approximate.
Yes, the level at the bed rail, or the body line just below it are good reference points to level. You can jack up the front end until you like the stance, then re-measure to see where you need to be from here to like your stance.
Remember to factor in any loads you'll be carrying regularly, because unless just very light stuff like a spare jacket, added weight might drop the rear a tiny bit. Even though just a small amount, if it puts that bed rail and body line down in the rear even slightly you'll be able to notice it.
Regarding the removal of individual leaves, the lowermost two leaves will net you a drop of about the thickness of the leaves themselves. No additional arch is added by these lower two leaves, so at about 1/4" thick each (though I think they're mm material) you'll get a drop of 1/4 for one, and 1/2 inch for two leaves.
But wait until you determine exactly what you have before you start removing leaves. It's not hard to do, but why go through the hassle if you're just going to need to add them back after new front springs.
J
johnbeck
Thanks Paul. The front is 6 3/4 to 6 7/8th inches. Do you have a preference for a stock, uncut, want to be kinda, sorta, semi-slick looking Bronco? How far off "bed line level" ? Thanks, John B
jckkys
The front coils were weak from the factory. Many wrongly assume age and use created the nose down stance. I know because I bought both my '73 and my '77 new. The Badlands Bronco history book has plenty of new (at the time) Bronco road tests with photos that tell us that a nose down stance was normal and the 4900lb. rear leafs sat higher. My original rear leaves are still about 1" higher than what we're told is stock ride height. The consistently weak front coils were simply replaced with '78 coils on my '77 to yield a level stance. Another often repeated fallacy is the idea that stock springs don't ride well. My 100 percent Bronco springs ride as well as any EB I've been in' The Fox shocks help some.
Still well within the stock range.
What's the rear? Might be falsely high with the new springs. But it might also be a visual thing until you get some reference points on the level body parts.
I like level, and I like slightly higher in the rear too. No preference personally. Just not too jacked up in the rear is all and I don't like the low in the rear look all that much. Very personal preference, so it's all about what you like.
Hence the recommendation to play with heights using a jack, a level and your eye's point of view.
sprdv1
REBEL
same same...
sprdv1
REBEL
Got any pics John ? :)
