wild horses sent me a new balancer and crank pulley
I had an overdrive pulley and the WH one is 1:1
Did you get a new water pump pulley too, or are you keeping the old one?
If old, what diameter is the water pump pulley? It's only 1:1 if the other pulley is the same size. If it was different along with the crank pulley, we'll have to re-calculate to see what you have.
wondering if my belts are going to fit back on with this new pulley it’s probably 3/4 in smaller.
Not very likely. You might have enough adjustment, but likely as not you'll need different belts. Only way to know is to wait and see, and install the old ones.
paul do you guys sell the overdrive pulley size?
No, never found the need. We patterned ours after the stock Bronco size that was on at least most Broncos. During the later years it's possible that there were different sizes used, but I've never seen a listing of what came on every EB over every year.
Paul btw the hash marks on this new balancer are really really faint. am I actually going to be using those for anything?
By hash marks, do you mean the graduated timing marks? I certainly
hope you're going to use them! At least some time.
Granted you did not take your distributor out, so your ignition timing has not changed. But at some point in every Bronco owner's life they need to check the timing.
Best bet is to paint the damper right now so it does not rust in a week (keeping the shank clean of course) and then scribing/scratching the paint out of the grooves where the timing marks are.
But only on the one set that lines up with your pointer at TDC. Some dampers have two or three sets of marks. You only use one per engine application.
Even though scratching off the paint will highlight the grooves pretty well, most of us will also highlight a couple of key lines with a white or silver high-lighter type pen.
Usually at the Zero and then at the 10° BTDC marks. If you have your pet setting for timing, then you would mark that one for sure. For example if you always set your timing at 14° BTDC then you would mark that one.
Put some oil on the seal and probably some oil on the shank of the damper too, so that it slides into the seal without catching a lip.
Not always necessary, but it's also a well known best-practice.
