back together again!
thanks everyone - really appreciate the advice.
it fired right up, only problem is the new alternator I put in is either not connected properly or its broken idk since i’m not getting about 12v in the cab now but I can sort that out this weekend. the one on there worked so I can fall back to that if I need to.
again thank you all very much. that was a job I was not looking forward to at all, I search for someone I could trust to do it for me but in the end I’m glad I did it at least once and I have a lot better understanding of what’s in there now.
It was a lot of work:
- new timing chain and gear set
- new timing chain cover
- new seals, new timing chain cover
- new dampener
- new alternator (new one is not working yet)
- new pulleys (back to stock sizes)
- new fan (back to stock shape/volume)
- new belts ($60 wtf happened to the price of belts?)
- stripped and painted the water pump
- new stainless pump and cover bolt set
- new/replaced all of the body panel bolts and clips for the grill
- discovered a crank seal in backwards and a mismatch between the timing chain gear set and the fuel pump eccentric
- painted the water pump cover
- replaced the thermostat seal and painted the thermostat housing
- few misc. other things... replaced all the header bolts (there were multiple types)
looks really good.
https://youtu.be/sLFhdP6DzNA
and here
https://youtu.be/iIIp-3KSJAI
