so the new 7820 timing chain seems to fit with the one piece eccentric
Does anyone know the torque specification for that bolt in the center of the fuel pump eccentric???
photos are below. I think it’s lined up properly maintaining the orientation between the crank and cam gears
As I said previously, I never had a problem with the same combo.
40-45 ft-lbs
Looks good
https://help.summitracing.com/app/answers/detail/a_id/4923/~/ford-windsor-torque-specs
does that chain need that red engine lube?
You sure are having some issues with this project.
It's a thread repair that some one installed because they over tightened and stripped the threads. A Heli-coil, or a Timesert are common "acceptable repairs" and it will be better than new.
The 1/4" bolts are tightened in INCH pounds.
yes i’m having some issues but I bet we get through them
i’ll buy a new cover and move on to whatever is next.
might swap the alternator while i’m in here
So........are your planning on replacing the pan gasket, or just patching in the front corners? Which ever direction you choose, just make sure you kept the dirt, gunk, and coolant from dropping into the oil pan.
It's possible that a timing cover can corrode and leak coolant which is why I asked you the question a couple of days ago. BUT it's much more likely to be a misdiagnosed leaking thermostat housing, that drips down into the valley above the timing chain cover. Look closely, use a small mirror under the housing and upper radiator hose.
