ChrisC74
- Joined
- Dec 9, 2010
- Messages
- 906
I played with making some adjustments to my Fitech system today. Overall I am happy with the way it is running right now but I think it can be better.
I keep seeing that the IAC steps need to be set between 6 and 10 for it to run properly. After it is warmed up I can get the idle set at 850 and the IAC around 8 or 10. This is done by making minor adjustments of the front and back adjustment screws on the throttle body and turning the truck off after each adjustment to let it recalibrate the TPS, etc.
The problem comes when I go drive it. I let off the gas and it drops to zero or one. It only rarely settles back to the eight to ten setting.
I can not figure out why it will not hold this setting. I get home, let it sit for fifteen or twenty minutes fire it up and it is back where it should be.
I am fighting a strong exhaust stink when I come to a stop or quick decel. On the few times the setting has stayed the smell was not there.
Anyone watch their IAC while they drive? Does your IAC number always return to the proper set point when you stop at a light or stop sign?
Thx,
Chris C74
Sent from my Pixel C using Tapatalk
Thx,
Chris C74
