Have a new blueprint 306 with Fitech 400. It runs great once I can get it started.
Prime shot setting was at 257 and for the most part it would fire right up when cold, but then was very hard to get it restarted when warm.
I turned down the prime shot setting to 200 and it seems to have made the warm starts only slightly better, but now cold starts take awhile. It cranks fine and you can hear it start to fire but then it dies. Eventually after cranking and cranking and trying anything I can with the throttle, it starts. I haven’t been able to determine a pattern for what makes it start.
Current settings
Prime shot - 200
Crank fuel 20f- 71.9
Crank fuel 65f - 29.7
Crank fuel 170f - 19.5
Crank IAC - 75.8
After start all set to 0
Can anyone advise what I need to adjust?
Thanks in advance.
Current settings
Prime shot - 200
Crank IAC - 75.8
Thanks in advance.
