...I'm also wondering about the white wire. I hooked it to the same wire that was hooked to my electric choke on the card. I thought it had power power on both starting and key on.
No, it does not. It literally gets power from the alternator and only has power (less than 12v) when the alternator is spinning and charging. It's not connected to the battery power in any way other than what it's pulling from the alternator.
Assuming we're talking about the original Ford wiring, it would actually be White with a black stripe. That's what Ford used for the electric choke on Broncos.
If this is the case, then that is indeed your stator wire from the alternator. If you need 12v in start and crank, find another source.
In a Bronco there are only two wires that have that characteristic that I know of. The Red w/green wire to the original ignition coil (resistor wire so not a full 12v either) and the Green w/red wire to the original voltage regulator.
Other than getting a jumper from the starter relay on the fender (small Brown wire) and assuming the ignition switch is still functioning as designed, those are the two with a voltage signal during crank and run.
