zombie66
for those of you running wheel spacers i would definately check your bolts occasionally and put loctite on the threads. we had a great time at browns camp that couldve turned into a real nightmare. i was airing up the tires and noticed some metal shavings around my hub. come to find out the bolts had worked themselves loose on my wheel spacer about a 1/4" on the driver side front and one or two bolts on the passenger side. the freeway ride home probably would have done the rest to the bolts and ended in a not fun situation. so i figured i would give you the heads up. im going to loctite the s#!t out of them today.
