For those running Toyota IFS PS Boxes - What Pitman Arm?
Pretty'LilThang
Davis
For those running IFS Toyota power steering boxes, what pitman arm are you running? Or what kind would you recommend?
-Thanks
P
Pretty'LilThang
Davis
The stock arm I have is pretty much flat. I am looking for something with at least a little drop to get the angle of the drag link down a little
getfuzzy
Look at Poly Performance I'm running the 3/4 les drop and is working out nicely
P
Pretty'LilThang
Davis
I will check them out. How much lift are you running? Are you running a stock drag link? I bought mine with a 6" lift, it will probably come down a little pretty soon, but until then if I run a pretty flat am I will get some wicked bump steer. Right? The drag link is pretty short and a 3/4" drop arm is going to give me a pretty steep angle. Maybe its time to just lower it a little
getfuzzy
3 1/2 " lift. 1 ton tie rods [tie rod over] and rod end track bar. They sell 3 arms flat 3/4 less drop and drop.
P
Pretty'LilThang
Davis
I am thinking of trying to use the stock Toyota arm till I can order a new one. Does the ball joint in the arm come out? If so whats the secret?
getfuzzy
X2 on Sky. Thats the one I got from Poly. I used the stock one after cutting out the ball and welding in the taper from the stock Bronco arm. Go with the Sky good price and much more safe.
toeneez
I'm using the stock yota arm and modified yota drag link. I had BC Broncos tread the yota drag link and the F150 link so I can connect them with a sleeve and adjust it. I've been running it like this for over 8 years.
