Ford 9" 3rd member case/housing cracked? Or casting mark?
tirewater
San Francisco Bay Area
While looking over my 9" housing, I noticed a lip in the metal that *could* be a crack. There is no sign of a crack on the inside of the housing.
Is there an easy way to determine if this is a crack or simply a casting mark? I've wire wheeled the clear coat off for a better image.
Heh, I can't seem to catch a break (no pun intended) with rebuilding my Ford 9 rear 3rd. Ultimately I've bought new gears, new trac-lok (x2 as one had severe runout), good used pinion housing, and now it seems a new 9" 3rd housing as well.
Thanks,
Chris
One break, comin' up!
I'd have to say it's a casting edge. Sure does look like a crack would look though!
But my vote is for casting flaw. Especially since you say it's not showing through.
The edge of it looks offset (one side higher than the other) so that's my clue.
Best of luck with it. Not sure how to truly test that theory (such as with Magna-Flux or whatever method) but there may be some way. Heating mildly with a torch to see if it opens up?
Not sure but if someone else's housing has that same one, you're good to go.
bax
Old Member
best way to tell is go after it with a sanding wheel. Smooth it out and see if it is a crack. Crack is wack
Timmy390
Conway, AR
First pic looks like a crack but the second and third look like casting.
Agree with some sandpaper....see if it smooths out......
Tim
broncosam
Looks like a casting mark to me, but I'd still sand on it a bit to be sure.
T
tirewater
Thanks, I'll grind it down some to see how far the imperfection goes. It's definitely a ridge/lip, but it's not obvious if it's cracked in addition to the ridge being there.
markatherton
crack
Clean the area thoroughly. Turn it upside down so you can pour oil in the area and see it it leaks through.
T
tirewater
I don't think oil will make its way through the crack. The crack extends into the casting. I believe it's likely a casting imperfection rather than a crack, but crack nonetheless.
I couldn't get a flapper in there, so I used the dremel.
Fun time$. This started off as fixing a leak, and has become a piece by piece replacement of the 3rd. Would've been cheaper to just to buy a completed 3rd. Lol...
Now I have to find another 2.89" 3rd case. Or scrap the new bearings I just pressed onto the carrier and buy a set of the 3.+" ones. I don't see much in the way of 2.89" 3rd member cases laying around.
bax
Old Member
at this point I think thats a crack. I may have a small case laying around but like you said. It's upgrade time.
5001craig
FWIW it looks like a crack to me.
Could you weld it up with some nickel or better rod? After disassembly. I seem to remember one of the electrode manufacturers made some rod that worked well and flowed well too. May require pre/post heating. Torch for preheating and cover in ceramic blanket to cool slowly. I've done this in the past on other items but I'd talk to someone more knowledgeable than me about your 3rd.
After confirming it's a crack.
WILDHORSES
USA
Crack or not I've noticed an uptick in housings breaking apart out on the trail. This stuff is 50 years old and if it's been abused or if you plan some abuse a good nodular housing will only set you back a few hundo.
Jim
T
tirewater
Jim
Thanks Jim. I have a Currie Nodular case coming to the house today or tomorrow. Ultimately my 3rd did have problems that may or may not be related to the case imperfections. In addition time spent finding a 'good' used case is considerable as this area is the land of no convenience.
The main annoyance is time wasted and spent on the existing setup. Cleaning and a ridiculous amount of assembling and disassembling. I'll be throwing away a second set of brand new carrier bearings when the case comes in (no aftermarket cases use the 2.983 bearings.)
suckerpunched
I might have one, I am a few hrs south of you. Is there an easy way to identify the 2.89 case vs the 3.0?
And don't throw away the brand new bearings just yet. Most members have the same size and someone might need them.
If you have the time to do it, they might go quickly.
