- Jun 1, 2007
- 363
Nice! I have an '05 6.0L diesel in an Excursion. I guess that explains where we stand, haha.
Are you going to put it in a Bronco?
Nice! I have an ‘05 6.0L diesel in an Excursion. I guess that explains where we stand, haha.
Just exploring all engine swaps before moving forward with my build. If simplicity was the deciding factor I would just rebuild the 302 that's in it.
I want to run fuel injection and 351W, or Stroker variants will require some adders (mustang/explorer efi, wiring harness, ecm, or aftermarket efi system, etc.). If there is an option available that rolled out of a current Ford plant with modern fuel injection, modern wiring, ecu that were all designed to run together then I want to at least look at the feasibility.
There are already super charger kits for the 7.3L Godzilla that are about $5500 and over 600 pounds of torque.
A twin Screw Supercharger is coming out soon too.
Considering the Much higher cost of the diesel, this is a Very good option if not towing heavy all the time.
Complete rebuilt with Supercharger are getting well over 1000 HP.
... but the Godzilla requires a $3500 add on self contained controller to run the engine, therefore this doesn't fit into your "designed to run together" parameters. Just pointing this out as any 351W stroker based motor is a TON simpler and easier to bolt into a Bronco (been done with EFI for over 20 yrs now) w/o an "unknown" controller that is brand new to the market- and only one controller on the market at this time can really cause i$$ues. If they go belly up and you need parts you have a $10,000 pile of almost obsolete parts that would have to be parted out or installed in an OE application.
This should make the Windsor based platform easier to look at.![]()
I'm no pro stroker builder by ANY means but after spec'ing and building more than a few I have learned that you can't go wrong in any way with an aftermarket block. They solve several potentially huge issues 100%. One is cooling, the other is block destruction (think '94-96 roller motor oil galley/cam brg issue).
If you go to dyno tuning places there are guys out there with Moates Qtrhorse tuning knowledge. Garry is great, wealth of knowledge, crazy guy who helps you out in time of need- can't beat any of those attributes! lol
Don't hate me forever but the platform that ain't going away unless ALL platforms are going away due to moving towards electrics or other future tech is the LS platform.
Just tossing this out there because switchbacking up a highway with a 6% incline for miles is different than crusing across flatlands when comparing power needs. I feel this every time I tow because I have a V10. lol A couple of these passes I cruise up them at 25mph in 1st as that's all I got. 2 others I can cruise up them at 40mph in 2nd WOOOHOOO. The new diesels with 475hp/1,000ftlbs pulling 35' toy haulers fly by me like I"m on 4 cylinders...
