Ford Godzilla Crate Engine
There is a lower cost intake out there. I remember seeing it a few months ago. Didn't book mark it as I am not foreseeing a project needing it.
hossbronco
Is that intake really $1100+? Has aftermarket options dropped the price any yet? I can see I'm only building old skool strokers for a while... lol
I paid less than that, but nearly all options are pricey. My understanding is that the 2023 version of the engine has a low profile intake for about $450.
PNW
I just kind of figured they'd be charging a fortune for anything & everything since the same engines made in 2019 are exactly double the price in the summer of '23. :(
hossbronco
All considered, the Godzilla is a relatively cheap crate engine. Even now, after several price increases, it retails at $8,500. That’s half the price of a 460 from Ford Performance and even cheaper than the 3.3L V6. I sold my new 427W stroker long block and got the Godzilla for several thousand less, and the 427W didn’t have an intake, oil pan, flexplate, exhaust manifolds, oil pump, water pump, valve covers, or distributor. Granted I’ll have to buy a controller, but I think the Godzilla is a great deal, especially when you can buy a pull-out engine for even less.
PNW
Glad you scored a deal for sure! They must really be pushing it. I saw the FP price on the 460 is/was over $16K.
Should be a great package. I like new stuff but I can tell ya this, I'm not pleased with anything that FP sells, designs, promotes and remotely has anything to do with. I had so many guys give me feedback on their FP engine stories it's pretty sad.
hossbronco
Yes, I learned that lesson from you. Fortunately the crate engine (excluding the upcoming Megazilla) should be just Ford production. The only thing I have that is FP at the moment is the intake manifold (the throttle body should also be a Ford production part).
rguest3
Levittownfordparts.com seems to have the best prices for the 7.3L Control Pack and Intake Manifold.
The least expensive Godzilla Intake I have seen is the Holley Intake. It's 2" Lower and you can use a variety of Throttle Bodies.
rguest3
I just got off the phone with the Ford Performance Tech Line.
I have the Ford Performance 7.3L Intake that calls for the 92mm Throttle Body - M-9926-M5292.
I have the Ford 7.3L Control Pack that has the 87mm Throttle Body Included with Adaptor. M-9926-M508 and M-9474-M5087
The Throttle Body and Adaptor included in the Control Pack are ONLY for the Stock 7.3L Crate Motor Intake. If you use another Intake with the Control Pack Throttle body or another Throttle Body to fit the Ford Performance Intake, you will have to get a re-calibration with a Chassis Dyno. Tech's recommendation.
I was hoping I could just get another Adaptor to make the Control Pack Throttle Body fit the Ford Performance Intake, but that is not the case. This adaptor is not only Not available but also Not recommended by the Tech at all.
hossbronco
The OBR control pack has several preset calibration options to choose from. The LP Ford Performance intake and 92 mm throttle body make up one of those options, though it is set for a stage 1 cam. If you’re in the market for a new cam, rumor has it that a new option for us NA folks is coming soon, likely in December. I suspect it will perform very similar to the Megazilla cam.
duffymahoney
Did anyone see this? 3" lower and with the new compact holley accessory drive. 2" higher oil pan. Looks like it might even end up shorter in height then a 302 now? Width is within an 1". I personally think the holley intake makes the engine look great. Modern, but not plastic, like the coyote. Classic valve covers and boom, nice looking motor.
https://www.holley.com/blog/post/ford_godzilla_swaps_made_easy/
Anyone know the height of a ford 302 with explorer efi?
hossbronco
Yes, Holley has come out with several nice offerings for the Godzilla, especially for the FEAD. Personally, I think this intake is ugly as sin, but I guess beauty is in the eye of the beholder.
The oil pan helps some, but I doubt it’s enough for a stock EB. Danbury also makes a pan that is 2” shorter than stock. They do this by modifying the stock pan.
Even with an air filter on top of the 302 there’s no way it’s taller than the Godzilla, based on the dimensions you provided. They indicate that the 302 is 20-1/4” with no air filter. Meanwhile, the Godzilla with these Holley parts is 28-1/4”. The only way you’re getting close is by installing the 1.7” dry sump pan or similar, but that still makes the Godzilla taller above the crank.
duffymahoney
That 20.75" without a carb or an air cleaner. 4barrel carb is 3-4" tall, air cleaner is at lease 2-3". So it could potentially be shorter.
hossbronco
I think the measurement is to the top of the distributor, and even then the air cleaner sits low on the carb. I’m not trying to hash this out too much, and maybe someone with a 302 and extra time can opine, but the point I was trying to make was even if you add those on top it’s still likely smaller than the Godzilla. Go with EFI and they shouldn’t be close. All the comparisons I’ve seen are with the 351W, and even then the Godzilla is taller.
duffymahoney
Well, the imagine I found online also might not be correct. I found the same image, but has the line for 20.25 at the valve cover.
Online I find 27.5-28.5" tall for the 302. I assume that is with an aircleaner
hossbronco
Good find! I was trying to find something like that. So the stock 302 with the air cleaner is 27-1/2” and the Boss 302 is 28-1/2”. I’m curious how much of that is above the crank, which is the more relevant number for me.
I thought the oil pump was a funky chain drive thing in the pan. I don't see room for that in the Holley pan. Am I missing something here?
hossbronco
From Holley:
“The Holley solution is to relocate the oil pump on the crankshaft snout under the front cover, much like other modern engines such as the GM LS and the Chrysler Gen III Hemi. This move eliminates the cumbersome jackshaft oil pump drive, which produces a much shallower front oil pan that can snuggle the deep-skirt block much lower into any engine compartment. The new Holley front cover was designed to use either the factory Ford jackshaft or the Holley oil pan system with the pump located underneath the cover. The expanded Holley kit (PN 20-320) includes the oil pan and front cover, plus the remaining critical components such as the oil pump, pickup, and all required hardware.
The expanded kit’s new Melling gerotor oil pump attaches to the inside of the front timing cover with bolts that are torqued only after the cover is in place.”
Honestly, the best wet sump pan for an EB with a stock front axle is KMF’s, but it’s not cheap. See the attached photo.
rguest3
From Holley:
The KMF products are very nice. I just wish they made Headers and Motor Mounts for the Godzilla / Early Bronco Swap.
Their Oil Pan looks great too, but it bolts to the Indy Power Oil Pan Rail. So additional Indy Power parts are needed for that pan to work.
rguest3
Here are two pics from Holley comparing measurements of their Products to OEM.
Holley Products include Front Drive System, Oil Pan System and Low Profile Intake.
