Found this on the internet.
lagbolt
badmuttstang
redneck grease monkey
Probably has a body lift if you look at the pic of the frontend flex you can see a body lift puck in there
broncnaz
If you look at the same pic as was mentioned it also appears the engine mounts have been modified so the engine has probably been lowered to provide the extra clearance needed.
broncnaz
If you look close there appears to be a flat piece of metal running from the frame to the motor. Which is not a stock motor mount so they must have lowered the mounts to help get the engine lower.
Even with a body lift I thought it was impossible
We try not to use the word "impossible" even with a truck EFI conversion.
But we typically recommend against it because it's still not a very desirable swap unless you're into really WORKING for it.
bmc69
Is it me or is that front crossmember part of a later-model one (F150?) replacing the original?
bmc69
My front cross member looks just like it and its stock
It looked like the bottom was open..C-type like the 150 and FSB. But I zoomed in on it and that was just the shadows..the original steering damper bracket is still in place.
I have to wonder how he lowered the engine without modifying the front cross member..?
...I have to wonder how he lowered the engine without modifying the front cross member..?
Dunno. But maybe he didn't? While you're zooming in, compare the height of the starter to the frame rail to see if you think it's still in the stock location or lower.
And what about the bottom of the mount in relation to the frame? They look lower to me, but I didn't really study it closely.
Maybe they're just reinforcing plates.
Still, it's hard to imagine one of those uppers sitting that low in an engine compartment without some serious mods having taken place. Whether lowering the engine, raising the body, or chopping the manifold in half and installing it on a 5.0 instead of a 5.8 (hey, every inch counts, right? ;D) or some other nefarious means of alteration.
Then again, maybe it's simply the camera angles. And they just chopped a big hole in the hood. The hood that we can't see.
I have seen it once. 3" of body lift. Another ½" of body shims in the front. Some obscure fiberglass hood that was really tall way far to the front. After all that there was still throttle rubbing the hood issues.
There are better ways to make it fit and make it run better.
