Front axle hub assembly tool
Boss Hog
What tool do I need to pull this aftermarket hub nut? Ive already pulled the snap ring. Also what brand is it? front end brake 001.jpg
BIGED
Guru ????
did you get both the axle snap ring and the large ring that holds the hub in ,
bmc69
As Biged said..once both snap rings are removed, the whole hub mess just pulls straight out. How easy it pulls out depends on how 'clean' the axles slines are and a few other potential hangups..but otherwise it just pops right out.
Skiddy
the large one is the one i always forget about beacuse there usually always crud around it%) you will also need the axle nut socket
BIGED
Guru ????
been there done that
Looks like someone is gettin new brakes
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Do you already have a hub nut tool? I'm guessing you do to get the nut off as far as you did, but you could have done it w/ a screw driver I suppose. If you don't have one you'll need it for re-installation definitely. Any of the vendors and most local parts stores will carry one for the Dana 44.
B
Boss Hog
Thank you sir. So I just ask for a hub nut tool for a dana 44. As far as I got was the small snap ring around the axle. I dont see another snap ring. I pushed the locking mechanism in to allow the snap ring room to open up to pull out. The haynes manual call for a tool but didnt tell me what kind. I will go by autozone tonight to get the socket and hopefully they have the brake lines. Then by sears to get a torque wrench.
Skiddy
the other snap ring is at the very end of the hub, yes on the dana 44 socket
RustyShackelfor
Centerville, TN
1/2 ton 4wd.
B
Boss Hog
Ok, got that figured out. Its the outside snap ring. Got it out with a small screw driver. Down to the spindle and grinding. In the instructions it says to grind but I cant see what its talking about. Here are some pics of were Im at. front end brake 004.jpg
chuck
Ingram, Texas
There is anothyer tool that works aq little better. The tabs thqat you see in the picture are on the inside so the tool stay on the nut much better. Looks/ sounds like you are installing the chevy disc so don't worry about the grinding until you put the caliper on without the pads. Then you will know what grinding and have an idea of how much. If you do it now you will be doing it more later anyway.
Rox Crusher
unless you use a torque wrench frequently...........another option is to rent one from checker o'rielly. They have a cool program where you rent it and if you bring it back in 48 hours it is no charge.
Other tools too.
B
Boss Hog
Not really sure if they are chevy, but they came from toms broncos. I have to stop to go on vacation and plus I need to order my new brake lines and the bushings for the support beams that attach to the axle.
Re-read what they say about grinding. It should say "knuckle" not "spindle" if I'm not mistaken.
Otherwise I don't know what you'd need (or want) to grind on a spindle for a disc brake swap.
When it all goes back together, do you have the bearing adjusting and final torquing procedure down pat? It's explained in the book, if you have one. If not, just ask and we'll run through the steps.
B
Boss Hog
I meant to say grinding the knuckle. No I dont know the procedure for the bearing installation. I was under the impression to just pack them with grease, then apply a light coate of bearing grease to all the internals but not to much to allow proper operations.
Skiddy
sounds like you got it figured out, just don't put grease on the locking hub assy. at most a light coat of lubricant on them. grease will make them gunk up and hard to turn the lock outs.
Steve83
Use the procedure described on the L side of this diagram:
Try to fill the space between the bearings with grease before installing the outer bearing, but DON'T fill the hub lock. It only needs a light coat of grease. Use grease specifically rated for disk brakes.
admin
Administrator
Phoenix, AZ
Good link Steve.
Boss, that's the correct procedure. Don't forget to read the text under the image too. It's important to turn the hub/rotor while tightening the inner hub nut. This helps make sure it seats properly and isn't cocked slightly, which could cause settling later and loosen things up.
The procedure and torque specs are critical, so don't breeze through it.
And I second (or third) what others have said about not packing the locking hub with grease.
In all this discussion don't confuse the two types of "hubs". There's the "hub and rotor" and the "locking hub."
B
Boss Hog
Thanks guys. I think I need to pick up another torque wrench that goes in in' settings. It is fathers day coming up, not to mention my bday today. What grease do you guys recommend, Skiddy you live close by so hopefully you will have some good answers. hehe Like stuff orielly or autozone carries. Thanks guys again.
B
Boss Hog
Ok, so after you tighten inner nut to 50 ft lbs then back off 90 1/4 turn, wouldnt that allow play in the bearings and produce premature failure.
