Front brake drum removal
RVZIO
New Smyrna Beach
On my 67 how do I go about removing the front brake drum. Looks like on later model;s you remove the spindle nuts and bearings. Is it the same for 67???
It's kind of a good way to go anyway. While checking/replacing the brakes you can also check, re-pack and readjust the wheel bearings as well.
A good practice since wheel bearings were to be re-packed probably every 25k to 45k miles anyway.
And with the number of PO's that did not know how to adjust them properly, it's always good to check their work if it's a newer purchase.
R
RVZIO
New Smyrna Beach
Thanks Paul, will do and I think that the bearings can be purchased at a NAPA?
.94 OR
Willamette Valley, OR
While you are in there, pop the slave cylinders apart and check their condition.
I'm redoing the rear end on mine which gets minimal use and found some nasties hiding in there.
Absolutely. They are some of the most common tapered bearings ever sold and are common to most Dana axles of similar vintage prior to the use of unit-bearings.
Should be no problem finding them in stock still at most parts stores.
The seal too.
McLeod
I agree that this is a must do.
But, in the interest of proper terminology, these are historically known as wheel cylinders.:cool:
R
RVZIO
New Smyrna Beach
I was scratching my empty head as to where are the slave cylinders. Wheel cylinders , ah got it. Disc brakes, yea some one has front wheel to wheel disc setup on marketplace for 750, OBO May look into that for later
Scoop
Bronco Old Fart
Cuchara, CO
I guess it’s not PC to call them slave cylinders anymore?? LOL
Then we’re going to need a new name for “master” cylinder too. Don’t want to trigger anybody! ;D
Cooper
Northeast
I always brace myself for an explanation to the counter person at the parts store as to what it is I'm looking for anyway, but my closest auto parts place is an Autozone.
bludorbronc
How to remove drum. Take hammer and pound out.studs and when studs are out take each stud and go to grinder and remove swedges on studs.when done drum will come off easily.next remove hub off spindle and pound or press studs then reinstall everything will come off easy.
