bronconut73
- Aug 7, 2012
- 9,919
Easy solution to the issue where our tall bump stops won't fit after the Trac-bar riser install.
Found these web surfing.
You can find them everywhere, Amazon, Ebay, etc...
But Summit had the pair for only $30.95.
Room for a few washers on the stud to make it even taller. I added two fat washers.
Also a tab that I needed to grind down a bit.
They look like leaf spring ie rear bump stops for a big truck.
91mm or 3.6" tall.
91mm or 3.6" tall.
