front calipers for conversion
matt w
I did a front disk brake conversion about 10 years ago and I want to replace the calipers. How do I find out "what type of caliper" I need to purchase from the auto parts store for replacement? the kit came from one of the sponsors on this web site. Thanks, Matt
savage
Bronco Nut
Renton
Where did you buy the front disk brake conversion from? I did mine about 10 years ago ,I bought mine from Toms Bronco. I called them and they told me what calipers I needed. Pictures will help.
matt w
matt w
Thank you - I found out they are from a k5 blazer!
Rustytruck
Just for reference to anyone looking at this post years from now. If your spindle is 6 bolt use 1974 chevy Blazer calipers. If your spindle is 5 bolt you can use 1977 Bronco calipers.
broncnaz
Or if you don't want to remove a hub to figure out what spindle you have just look at the calipers themselves. the GM caliper will have 2 slider bolt/pins holding the caliper to the backing plate which is maybe 1/4" stamped steel. If you have ford style brakes the caliper bracket is thicker cast steel and has one sort of diamond shaped slider pin on the lower side.
