Front End Steering Set-Up?
matt w
I NEED to upgrade my front end steering.
I have a D-44 front end and "I think" since I am doing it I want to modify it to the tie rod over the knuckle.
I have a 3 1/2 inch lift and am running 33's with really no plans to go to bigger tires, however I do have plans of putting some sort of locker in it. I also have already installed a Tom's Disk Brake Conversion set up on it & it has been working flawlessly!
I am thinking of the Extreme Custom Fabrication product.
1) What are thoughts and opinions on making an upgrade such as this?
2) Also are there any other options or manufacturers that you would direct me to?
Thanks!
Matt W.;D
trailpsycho
I was going to suggest the Chevy HD TRO setup...which is what ECF sells. Nice option. Very HD. I picked up my reamer at a local Northern Tool or similar shop in town. I bought all my ends locally (NAPA chasis-line), chromo tube (1.25" OD and 0.75 ID) and the drill and taps (via www.etaps.com). We tapped the tube on a friends lathe and now we have the tools to make more. At the time, I had about $250-275 in parts and tools. This was still far less expensive than some of the setups sold by the vendors.
Mike (of COR--at the time, now ECF) had them priced a little higher back then...pretty close to what I had invested. Last time I looked, he had the whole setup even cheaper. If you dont have all the stuff, he has a great price on that product...after all, there is a decent bit of work putting these together. You have to also ream the PS rod end (if you DIY). As well, you will need to ream the pitman arm as well, dont forget that.
Either way you go you will have to ream out the knuckles. Use tape on the reamer (mic it for appropriate diameter) and cut it slowly with lots of oil (WD-50 or PB Blaster work OK). If you can remove the knuckle and pitman arm and ream with a drill press, that would be ideal...just easier to control. You can do them still on the truck as well...just be sure to not over-ream.
Good luck.
John
matt w
matt w
Good luck.
John
..John thanks for the input...I wanted to be able to do the conversion w/out pulling the knuckles and was hoping to hear from others here that have done this type of conversion?
ACTUALLY to make an honest confession I was going to have a friend that ownes a brake, tire and alignment shop do this for me. He kinda likes this stuff as it is out of the norm of the same ol, same ol with all the other regular customers..But I did want to keep the labor/intensity down on it...even though he does like to help me out!
.....hmm??;D ... It seems like this might be the right upgrade.
turbotim2
____________
What year is the front axle? The stock 76-77 disk brake front axles will run into a clearance issue with the TRO tie rod ends and the wheels if you backspacing is too high. Just something to think about.
orangecrush4u
Shelter Island, NY
I did the heim over the knuckles with the 3.5 lift and I ran into issues, first you need a stock pitman arm, not a dropped. After that the steering was still kinda scary, so I put the heim under the knuckle which helped a lot. The tract arm angle was still not how I wanted it so I ordered adjustable tract bar and a riser for the axle. I am going to do adj tract bar first and see before I put the riser plate on. I am still running drum in the front so I have no idea what isseus I will encounter when I do that job. I also had issues when I wanted to run dual shocks the tabs were to close the the heim joints so I am having new ones made. There are easier ways and other steering systems that I think work great and are easy. I would say if you going rock cawling then go with the heim. I went in over my head and wish I just did the y steering setup. I'm also running a sparton locker in the front, seems to work great after I upgraded to chrome moly axles%)
Greg_B
Cohutta, GA
If you have access to a lathe or a machine shop you can use the 78-79 F150/ BB linkage... it can be used either under the knuckles like stock or reamed from the top. I reamed mine with the knuckles on the Bronco... took about 15 minutes and I took my time. I did switch to F150 Knuckles since I have a 76 EB though.
Greg
matt w
matt w
Oh I forgot to say that I have already installed a TOM's FRONT BRAKE disk brake conversion on my 1973 truck. For those that were helping me with this issue. I do alrady have a dropped pitman arm installed also;D
Thanks guys!
turbotim2
____________
If you go TRO, you will need to use a stock pitman arm and a trac bar riser off the axle. If you plan to go tie rod under, use the drop pitman arm and you can use a drop trac bar bracket on the frame.
Greg_B
Cohutta, GA
When I first put the F150 linkage on it was better than the inverted Y setup but still crazy to drive with the drop pitman arm. I flipped it to the top and went back to the stock pitman arm and it now drives great... Compared to the stock setup it drives like a sports car.
Greg
trailpsycho
As was mentioned, if you are going to go TRO, you probably want to add an axle riser bracket, ditch the drop pitman arm and go with a stock pitman arm...and likely may need the adjustable track bar to sync it all up right.... You and your buddy will have a great time; him installing it all and getting it all dialed in adn you WILL really enjoy how it drives.
These are all things I did as well. You know, Matt, its the snowball effect...one good upgrade deserves another.
matt w
matt w
..Hmmm, you guys all have me thinking! AND wondering about cost. I guess I am glad I still have the stock pitman arm from when I did the lift!
...So I gotta ask "What is a axle riser bracket" got any pics of what it looks like and where it goes!? AND how much is THAT also! heh-heh%);D
turbotim2
____________
I got my trac bar riser from Bernie Kiser. It is really well made and a bit cheaper then the Wild Horses piece I think. His email is broncogt@yahoo.com and it was $50 + shipping. The riser basically moves the mounting point for the trac bar on the axle up and gets it out of the way of the drag link for TRO applications.
Pedestrian
Bronco Missionary
I started out with a drop track bar bracket, which had clearance issues and broke in very short order. I got a track bar riser from Randy a Driven auto parts. Seriously heavy duty, works great and easy to install. TRO with stock pitman arm 3.5 lift and 33s. Works great.
tinytim02
x2
Great product at a great price. He is real easy to work with and answered all my dumb noob questions. Do a search here for "kiser riser" and you'll come up with a lot of good info.
trailpsycho
I was out of the loop on the Kiser Riser, until after I had already ordered the WH version. WH version is nice, it offers multiple holes, depending on if you have 3.5, 4.5 or 5.5" of SL.
Matt- if you do some TRO searches going back about 3-4 yrs, there is alot of info on why the axle riser vs the drop track bar bracket. Ultimately, the axle riser is a stronger setup...your axle tube is much thicker than the frame. At 1/8", with a the leverage of the drop track bar bracket alot of folks were cracking and or tearing their frames with tires from 33" and up...although its more common with larger tires (offroad conditions). By keeping the track bar frame mount end as close to the frame as possible (stock position) there are less forces working on the frame and integrity is OK. Raising the lower end of the mount at the axle allows the proper geometry to be maintained and all is good with the world.
Yes, you can feel the snowball....its coming... Have fun and Good luck.
matt w
matt w
Ya know it feels more like I'm experiencing "getting pelted with snowballs"! (plural) heh-heh But yep looks like I will have to build a snowman out of them!;)
matt w
matt w
ok I "think" I am getting ready to purchase "parts" for a steering upgrade.
I have a D44 up front.
I have wheels with 3 3/4 back spacing. I am running TOM's disk brakes!
I have read of "clearance" issues with certain set ups.
I want to go tie rod over knuckles as long as I can still have the same turning radius and no clearance issues.
Is this possible with something like this? I just do know what kit to purchase!%) Thanks Matt;D
http://extremecustomparts.com/i-361167-tie-rod-drag-link-dana-44-1976-1977-bronco-1-1-2-d-o-m.html
HERE is the exact wheel I have : http://www.summitracing.com/parts/CRR-3645855/
The biggest issue is when using the '76/'77 EB knuckles. All the others seem to work ok with these steering setups as long as the wheel rim edge isn't some exotic thing that is super thick (like some case aluminum wheels are) or the backspacing isn't too radical.
Your 3.75 shouldn't be too bad (might be close though) I wouldn't think. But wait for others with more recent experience to chime in.
matt w
matt w
Thanks paul...here is the exact wheel i have I am interested in getting all the parts needed to make this eventually happen.
I guess I do not have to go tie rod over BUT I know that would be best if I do do the upgrade!
The only reason I would not is if there are issues with my wheels because I am not changing my wheels out!;D
bell55
Ventura, CA
Check out bullet proof steering. I went with the race proof tubing and Stage 2 rod ends. They make a nice product.
